I have an issue with my trane stat used in conjunction with the BLStat program, Blade has been trying to help but we can't figure out what would cause it, We are wondering if there are any other HS users having the same issue?
Basically every time I start homeseer or click Reinitialized thermostat in the BLStat plugin, My trane stat changes to Energy Saver Mode (ESM) automatically.
I normally keep my stat either on "Hold" or "Run" but like i said, it changes to ESM mode once homeseer starts or the thermostat is reinitialized.
Does anyone else seem to experience this issue? Can other people try putting there trane stat either on run or hold physically on the thermostat and then goto reinitialize thermostat in the BLStat plugin and then physically go check the thermostat and see if it changes to ESM mode with 15-20 seconds?
-Tom-
-Tom-
