Version 3.4.0.0 was placed in the updater and includes the general additional of charting of HS device value history using the same mechanism that has been provided for MQTT payload charting.
A new "D"evice column has been added to the Association tab, Chart tab item selectors now accept either topic or device reference, General tab adds a row to save all or only items checked in "D" column, and the LastDate now has a hyperlink to pop up a chart for Device history just like the Payload hyperlink does it for Payload history.
For the case of the mcsMQTT rate and accum devices, the checkbox for the base device should be used and all the devices associated with this base device will be save to the database for charting.
The association tab columns have been rearranged to the right-most two (D and LastDate) provide the charting control for the HS devices. Next to these (H and Payload) are the charting control for Payloads.
Charts on demand are done in the same way for Device Values as was done for MQTT Payloads with the only difference being that a number (Device Reference) rather than the MQTT Topic is the parameter to identify the item being requested.
