I installed a new FanLinc and a 6-button KPL. I configured the KPL so that that buttons B, C, D, E are in a radio group. I linked these buttons to the FanLinc as Fan Off, Fan Low, Fan Med, Fan High. Pressing the KPL buttonw works great and the fan responds as expected. The problem is that no matter what button is pressed (even off), Homeseer reports the Fan status as "HIGH" (value 100) unless and until the device is polled. Other than set the polling to 1 min is there a way to have Homeseer correctly report the fan's status?
Fanlinc Status Reporting
i would suggest an event to perform the status request based on the insteon trigger 'transmits a on command'. one event for each of the 4 kpl btns: b,c,d,e
the action should look like this. its a script action
hs.polldevice("a1")
replace a1 with the device for the fanlinc fan control hs deviceMark
HS3 Pro 4.2.19.5
as an alternative, you might enable the 'Sync linked responder devices' on the kpl device to see if that will update the fanlinc. no guaranteesMark
HS3 Pro 4.2.19.5
