"Device Status Change" trigger "Changed to ON"
    Zwave environment. HS 2.5.0.21
    What is supposed to happen to an event triggered by
    "Device Status Change" --> "Changed to ON"?
    when the device being checked is polled?
    I am seeing the event fires every time after the device is polled. If the device was ON, then polled (via recurring event or automatically via switch configuration), and found to still be ON, the event is triggered again as if the device was just found to be ON for the first time. I expect the event to trigger only when the device moves from OFF to ON.
    I feel this is wrong because the event fires when the status is not actually changed.
    That is a bug - it is not the polling, but the fact that it changed from one dim level to another, or from ON to DIM or DIM to ON - it triggers on the change, but it should not if it was already on or dim. Should be easy to fix in the next update.
    Rick Tinker (a.k.a. "Tink")
      Rick should he put in a bug report on this or have you already taken care of that?
