Go Back   HomeSeer Message Board > Audio / Video and Infra-red (IR) Plug-ins > Audio / Video and Infra-red (IR) Discussion > AirplaySpeak
AirplaySpeak This plug-in is a Speak Proxy which allows Homeseer to route annoucements to AirPlay capable devices such as an AirPort Express
  #21
Old June 16th, 2013, 10:10 PM
norcoscia's Avatar
norcoscia norcoscia is offline
FYI - I have never been able to get this to load
Just wanted to let you know the error I had reported is still happening. I'm on .8 now and have tried loading other plug ins - I have never gotten airplay to load on HS3
GearHouse Club Member
Intel Ci5 1.49 GHz / Win7 Pro 64 / 4G RAM
HSPRO v2.5.0.81 / Z-Troller / 30 Z-Wave devices
HSTouch / UltraWeatherBug / Insteon / ADIO-100 / EtherRain / SONOSCONTROLLER / UltraNetCam / BDGraphs / Pushover (3P) / EnvisaLink / AirPlay Speak
  #22
Old June 17th, 2013, 09:57 AM
gearyt's Avatar
gearyt gearyt is offline
Super Seer
I was able to load AirPlay back at .6 ( now at .8 )
but I am getting the error w/ Global Cache
Ubuntu 16.10 (64) | HSPro 3.0.0.297 | Z-Wave 3.0.1.124 | Server .94 | BL BackUp | BLOccupied | BLLock | Media Controller | Jowi HUE | HSTouch | DSC-Envisalink | I-Tunes DAAP | DirecTV | Restart | Honeywell WiFi | Weather XML | RFX Com | + Android .117 : IOS 8
  #23
Old June 18th, 2013, 03:53 PM
spud's Avatar
spud spud is offline
Moderator
I tried installing HS3 (3.0.0.8) + Airplay Speak on another computer and I got the " Failed getting InterfaceStatus from AirplaySpeak " error, but this was because I forgot to install the Bonjour service. After installing Bonjour like explained in other posts, everything was ok.
If you still got an error after making sure that Bonjour is running, please try the following to troubleshot the problem.
1) start HS3
2) open a dos console
3) go to your HS3 root dir: cd "C:\Program Files\HomeSeer HS3\"
4) start the Airplay Speak plugin from command line: HSPI_AIRPLAY_SPEAK.exe
Then please copy/paste here what is printed to the console
  #24
Old June 18th, 2013, 08:33 PM
dlover dlover is offline
I'm having this same issue. I verified that I have Bonjour installed. In fact, when I tried to install it again, it asked me if I want to repair the installed version or remote it.
Here's my CLI result of running HSPI_AIRPLAY_SPEAK.exe
c:\Program Files (x86)\HomeSeer HS3>HSPI_AIRPLAY_SPEAK.exe
Plugin: AirplaySpeak Instance: starting...
Connecting to server at 127.0.0.1...
Connection attempt #1
Connected (HomeSeer API 3). Waiting to be initialized...
Connection lost, exiting
Disconnected from server - client
SendInvokeResponse: Cannot access a disposed object.
Object name: 'System.Net.Sockets.Socket'.
___________________________________________________________
Hardware ==> Virtualized on Hyper-V (Windows Server 2016)
O/S ==> Ubuntu Linux (16.04.3) and Mono 5.4.1.7
Homeseer ==> HS3-Pro==> 3.0.0.435 - Controllers: 1 local Z-Net, 1 remote Z-Net (Z-wave plug-in 3.0.1.210)
369 Devices (44 Z-Wave Nodes)
Plugins: Nest, Z-Wave, HSTouch Server, weatherXML, BLBackup, BLLAN, Sonos, MyQ, Pushover 3P, Honeywell Lyric
  #25
Old June 22nd, 2013, 09:12 PM
Any suggestions???
  #26
Old June 23rd, 2013, 04:08 AM
spud's Avatar
Moderator
Any suggestions???
Sorry for the delay, I'm on vacation.
Did you try the HS2 version of AirplaySpeak? Does it work? And is it installed on the same machine as HS3?
Any difference if you don't run HS3 as a service?
i'm going to create a version with more logs.
  #27
Old June 23rd, 2013, 04:12 AM
spud's Avatar
Moderator
Also, make sure that HSPI_AIRPLAY_SPEAK.exe is not blocked by your firewall or antivirus. Try to shut them down and restart HS3.
  #28
Old June 24th, 2013, 08:41 PM
Tried it in HS2. Won't stay enabled there either. Also tried running HS3 NOT as a service. Still no go. The logs show this
7:39:04 PM Error Initializing plug-in(1): AirplaySpeak Instance::HSPI::InitIO: Failed to init: Exception: System.NotSupportedException: An attempt was made to load an assembly from a network location which would have caused the assembly to be sandboxed in previous versions of the .NET Framework. This release of the .NET Framework does not enable CAS policy by default, so this load may be dangerous. If this load is not intended to sandbox the assembly, please enable the loadFromRemoteSources switch. See http://go.microsoft.com/fwlink/?LinkId=155569 for more information. at System.Reflection.RuntimeAssembly.nLoadFile(String path, Evidence evidence) at System.Reflection.Assembly.LoadFile(String path) at Mono.Zeroconf.Providers.ProviderFactory.GetProviders() at Mono.Zeroconf.Providers.ProviderFactory.get_DefaultProvider( ) at Mono.Zeroconf.Providers.ProviderFactory.get_SelectedProvider () at Mono.Zeroconf.ServiceBrowser..ctor() at HSPI_AIRPLAY_SPEAK.SpeakerDiscoverer.Start() at HSPI_AIRPLAY_SPEAK.SpeakerManager..ctor() at HSPI_AIRPLAY_SPEAK.AirplaySpeakApp.Init() at HSPI_AIRPLAY_SPEAK.HSPI.InitIO(Int32 port)
  #29
Old June 25th, 2013, 11:58 AM
spud's Avatar
Moderator
these logs show that the system can't load one of the Airplay Speak dll because it is blocked by windows because it has been dowloaded from internet. Please try the following:
in windows explorer right click on Mono.Zeroconf.Providers.Bonjour.dll and click unblock at the bottom of the window.
do the same for each of these dlls:
- HSPI_Airplay_Speak.dll (HSPI_AIRPLAY_SPEAK.exe for HS3)
- Mono.Zeroconf.dll
- NAudio.dll
then restart HS
let me know if that fix your problem in HS2, and/or HS3
  #30
Old June 25th, 2013, 08:36 PM
The good news is that your suggestion on unblocking the files did the trick. Plug in connects just fine. Bad news is that I can't get it to play over either of my two Apple TV's. I get this in my logs.
7:31:46 PM AirplaySpeak TEARDOWN rtsp://192.168.1.10/4150746390 RTSP/1.0CSeq: 6Session: 1User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 951017AA12154360
7:31:46 PM AirplaySpeak RTP-Info, rtptime=116673
7:31:46 PM AirplaySpeak Server, AirTunes/160.10
7:31:46 PM AirplaySpeak CSeq, 5
7:31:46 PM AirplaySpeak FLUSH rtsp://192.168.1.10/4150746390 RTSP/1.0CSeq: 5Session: 1RTP-Info: seq=2115;rtptime=116935User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 951017AA12154360
7:31:44 PM AirplaySpeak Server, AirTunes/160.10
7:31:44 PM AirplaySpeak CSeq, 4
7:31:44 PM AirplaySpeak SET_PARAMETER rtsp://192.168.1.10/4150746390 RTSP/1.0CSeq: 4Session: 1Content-Type: text/parametersContent-Length: 20User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 951017AA12154360volume: -15.000000
7:31:44 PM AirplaySpeak Audio-Latency, 175
7:31:44 PM AirplaySpeak CSeq, 3
7:31:44 PM AirplaySpeak RECORD rtsp://192.168.1.10/4150746390 RTSP/1.0CSeq: 3Session: 1Range: npt=0-RTP-Info: seq=1901;rtptime=41607User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 951017AA12154360
7:31:44 PM AirplaySpeak Audio-Jack-Status, connected
7:31:44 PM AirplaySpeak Session, 1
7:31:44 PM AirplaySpeak Transport, RTP/AVP/UDP;unicast;mode=record;server_port=59993;control_port=59053 ;timing_port=51111
7:31:44 PM AirplaySpeak CSeq, 2
7:31:44 PM AirplaySpeak SETUP rtsp://192.168.1.10/4150746390 RTSP/1.0CSeq: 2Transport: RTP/AVP/UDP;unicast;interleaved=0-1;mode=record;control_port=52131;timing_port=52130User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 951017AA12154360
7:31:44 PM AirplaySpeak CSeq, 1
7:31:44 PM AirplaySpeak ANNOUNCE rtsp://192.168.1.10/4150746390 RTSP/1.0CSeq: 1Content-Type: application/sdpContent-Length: 183User-Agent: iTunes/4.6 (Macintosh; U; PPC Mac OS X 10.3)Client-Instance: 951017AA12154360v=0o=iTunes 4150746390 0 IN IP4 192.168.1.10s=iTunesc=IN IP4 192.168.1.103t=0 0m=audio 0 RTP/AVP 96a=rtpmap:96 AppleLosslessa=fmtp:96 352 0 16 40 10 14 2 255 0 0 44100
7:31:44 PM AirplaySpeak (Apple TV Man Cave): This is just a test!!!
7:31:44 PM Event Event Trigger "On Demand AirSpeak"
7:31:44 PM Event Event On Demand AirSpeak triggered by the event page 'Run' button.
  #31
Old June 25th, 2013, 08:42 PM
spud, I think I may have figured it out. I just read your "feature" request thread and saw that you were adding support for password protected devices. My Apple TV's both are password protected. Any idea as to when that feature may be available?
  #32
Old June 26th, 2013, 01:33 AM
spud's Avatar
Moderator
Could you confirm that it works if you remove the password on your devices?
Not sure when this feature will be available (very few people have asked for it)
  #33
Old June 26th, 2013, 07:31 AM
norcoscia's Avatar
clicking allow fixed the issue for me
HS3 Plug-in is now working - I still need to understand how to point it a speaker - spoke a test command and it switched my stereo to airplay mode.
  #34
Old June 26th, 2013, 11:13 PM
spud, yes, I was able to get it to work with my Apple TV's if I removed the passwords.
  #35
Old June 29th, 2013, 07:39 AM
spud's Avatar
Moderator
I have uploaded a new version of the plugin (3.0.0.0) which fixes the initialization problem (without having to unblock dll) and add some better logging mechanism.
  #36
Old July 24th, 2013, 12:28 PM
spud's Avatar
Moderator
password protected devices are now supported
you need version 3.0.0.2 (attached to the first post in this thread)
  #37
Old August 21st, 2013, 09:50 PM
spud's Avatar
Moderator
version 3.0.0.3 fix a bug affecting old Airport Express (firmware <= 6.3) with password
  #38
Old August 23rd, 2013, 12:41 PM
gearyt's Avatar
Super Seer
It now be working for me... Thanks
just needed to add the delay after the .3 update was installed !!
AND .. I really like your new I-Tunes plug-in .. (after waiting years for the HS one to debug)
Thanks Spud !!
  #39
Old December 26th, 2013, 06:19 PM
norcoscia's Avatar
Hi Spud
Hi Spud, hope you had a good holiday.
I decided to start working on HS3 a bit more seriously since it has come a long way in the last few months.
I went ahead and paid for my AirPlay speak HS3 upgrade and installed it on a new PC running win 8.1 since this is one of my favorite plug-ins.
For some reason it does not seem to be able to find my Airplay speakers. I'm still running HS2 w Airplay but assuming that is not the issue. See pic below. Do you have any ideas what might be causing this?
BTW, I loaded Bonjour and assuming this is not the problem either since Airplay would not initialize until I did.
PS. Airplay is 3.0.0.2 and HS3 is .54
  #40
Old December 26th, 2013, 06:28 PM
spud's Avatar
Moderator
could you set the log level to debug, then restart the plugin, and post your logs here.
also try to disable any AV and firewall, that may prevent the plugin to discover your Airplay devices
Tags
airplay speak, hs3, version
Airplay Speak Feature Requests spud AirplaySpeak 27 June 12th, 2018 03:13 PM
Airplay Speak plug-in general information spud AirplaySpeak 41 November 2nd, 2017 10:27 AM
Airplay Speak - HS3 User Guide spud AirplaySpeak 1 January 21st, 2014 05:22 PM
Airplay Speak - HS2 Beta Testing spud AirplaySpeak 82 July 24th, 2013 06:45 PM
Airplay Speak - HS2 User Guide spud AirplaySpeak 0 March 4th, 2013 05:32 PM
