Hi Mark - I'm enjoying your Vista plugin! I just integrated my Amazon Echo with my Home Seer and have run into a small problem. The Alexa app can't seem to understand commands where the status text is hyphenated or has a space (Arm-Away or Bypass All as an example). Alexa understands "Disarm" with no problem, and if I change a Status text to another word Alexa will understand it (e.g. "Alexa, tell HomeSeer to set Security to Away" instead of 'Arm-Away'). However, if I change the status text from the pre-configured values, the plugin doesn't correctly send the command to the Vista system. I'm guessing it's due to this thread in the Insteon plugin: http://board.homeseer.com/showthread.php?t=176882
I'm wondering if you were able to fix the KLM button issue in this thread and if the code fix could be ported to the Vista plugin?
Josh
Josh
