Go Back   HomeSeer Message Board > Audio / Video and Infra-red (IR) Plug-ins > Audio / Video and Infra-red (IR) Discussion > AirplaySpeak
AirplaySpeak This plug-in is a Speak Proxy which allows Homeseer to route annoucements to AirPlay capable devices such as an AirPort Express
Old August 13th, 2016, 10:05 AM
stevenseh@gmail.com stevenseh@gmail.com is offline
Intercept AirplaySpeak error
In some cases my speaker goes awry and AirplaySpeak throws an error message in the log. Is it based on an error code of the speak command? How could I intercept that error and based on that for example send a text message to alert me to reboot my speaker (that usually solves the issue).
Old August 15th, 2016, 06:41 PM
I use the below script to look for a 'failed connection' message in the log. Feel free to copy and adapt. I'm using a Global variable to keep track of the last time i searched the log, and trigger the script like every 10 minutes from an event. If it finds a failed connection log entry, it calls another event.
Are there other errors that are issues in the log that i could look for?
Btw, it would be easier if log entry were marked as error instead of info...
Sub Main(parm as object)
Dim Logs() As HomeSeerAPI.LogEntry
Dim lngIndex as Long
Dim LocDate as Date
Dim LocTargetLogType as string = "AirplaySpeak"
Dim LocTargetText as string = "INFO Connection to iW3 (192.168.0.105:1024) failed"
Dim LocLogText50 as string
Dim LastRan As Date = #8/14/2016 5:02:00 PM#
Dim NewLastRan As Date
Dim FoundDrop As Boolean = False
NewLastRan = Now
LastRan = hs.GetVar("lastlogscan")
Logs = hs.GetLog_Date(LastRan, NewLastRan)
hs.SaveVar("lastlogscan",NewLastRan)
If Logs IsNot Nothing Then
For lngIndex = LBound(Logs) to UBound(Logs)
If String.Equals(LocTargetLogtype, Logs(lngIndex).LogType) Then
LocLogText50 = Logs(lngIndex).LogText.SubString(0,50)
If String.Equals(LocTargetText, LocLogText50)
LocDate = Logs(lngIndex).LogTime
hs.WriteLog("Info", "Found AirplaySpeak drop at " & LocDate.ToString("G"))
FoundDrop = True
hs.TriggerEvent("AirplaySpeak Speaker Dropped")
Else
' hs.WriteLog("Info", LocTargetText & "-" & LocLogText50)
End If
Else
' hs.WriteLog("Info", LocString & "-" & Logs(lngIndex).LogType)
End If
Next lngIndex
End If
If FoundDrop = False
hs.WriteLog("Info", "No AirplaySpeak drops found")
End If
End Sub
What does Intercept Speaker Devices do? matt246 PI-SonosController (3P) 1 March 20th, 2016 10:34 AM
Reset AirplaySpeak? czfyjf AirplaySpeak 2 March 24th, 2014 08:00 PM
AirplaySpeak and Loquendo voices spud AirplaySpeak 0 December 5th, 2013 08:38 PM
Any way to intercept local action xxrzdxx HomeSeer Z-Wave Plug-in 1 January 19th, 2011 08:40 PM
Intercept voice command.... zippy HS2 / HSPRO 1 September 29th, 2006 05:50 PM
