Go Back   HomeSeer Message Board > Audio / Video and Infra-red (IR) Plug-ins > Audio / Video and Infra-red (IR) Discussion > AirplaySpeak
AirplaySpeak This plug-in is a Speak Proxy which allows Homeseer to route annoucements to AirPlay capable devices such as an AirPort Express
Old September 12th, 2016, 01:05 AM
Rvtravlr's Avatar
Rvtravlr Rvtravlr is offline
Delay between speak command and actually hearing it.
Is there a way to decrease the delay between when HS speaks something and I hear it on the speakers?
Old September 20th, 2016, 10:19 PM
Rvtravlr's Avatar
Spud? Can you comment?
Old September 21st, 2016, 12:38 PM
spud's Avatar
spud spud is offline
Moderator
I'm not sure I can do something for that.
How long is the delay you are experiencing? What kind of Airplay Speakers do you use? In the Config page do you have the "Delay Before" setting set to > 0?
Old September 21st, 2016, 10:10 PM
Rvtravlr's Avatar
The delay is approximately 39 seconds between the time it is heard on the HS computer and then the AirPlay speakers which are a combination of Philips and JBL.
No delay is set on the config page.
I have several events that speak, such as when the doorbell is pressed. By the time it is announced, sometimes the caller has left.
Any help to resolve this would be appreciated.
Michael
Old October 23rd, 2016, 06:51 AM
edwilloughby's Avatar
edwilloughby edwilloughby is offline
Delay
I have the same issue with delay.
Also HS plugin sees the speakers in the config but, fails at times to use them, when this happens I can check network and 'see the speakers by both name and IP'. If I restart HS the speakers will once again work for a while then HS will quit using them. Sometimes this will be days and some times this will be hours between loss of speech.
Don't know where to turn.
BTW when HS fails to speak I can use IOS Airplay to play music via the same speakers that HS is not using.
Ed
Old October 24th, 2016, 01:46 PM
bump!
Any input Spud
Old October 24th, 2016, 09:46 PM
Rvtravlr's Avatar
Ed,
First off, look at this http://board.homeseer.com/showthread.php?t=184244
Also, what kind of AirPlay speakers do you have? I have a bunch of Philips and they needed a firmware update.
Since the firmware update and the router settings I'm pretty satisfied. I would like instant speaking through the AirPlay speakers, but 3-5 seconds is okay.
Michael
Old October 25th, 2016, 07:43 AM
Spker droping and delay
Originally Posted by Rvtravlr View Post
Ed,
Michael
Thanks Michael for the reply,
I use the ASUS RT-AC88 router and have tried your settings from your earlier post, I did not see any difference in the delay in speech. I was fairly the same.
As for the speakers, Well I started with iHome IW3's and now have 3 additional phillips. They all routinely drop off of the network and many times will show up on the network and play airplay but not HS speech.
All speakers are at the latest firmware release. I had to call Phillips to get the latest from them.
Any help is welcome.
Ed
Old October 25th, 2016, 08:08 AM
spud's Avatar
Moderator
can you try to connect one of your speaker directly to your router using an ethernet cable to see if the problem is your Wifi connection?
Is there also a delay when you target only one specific Airplay speaker?
Could you set the log level to debug, and post them here for the case where there is a big delay or when it fails to respond. Please use only one speaker for this, otherwise the logs will be very difficult to read.
Old October 25th, 2016, 10:47 AM
debug
Thanks for the reply Spud. No the speakers do not have a Ethernet connection only WIFI.
I will unplug all of the speakers except for one IW3 and one Phillips and set the log level to debug. Will have to wait till I get home from work tonight.
Ed
Old October 25th, 2016, 11:08 AM
Log
Ed
Turned it on remotely just for a fer min and ran speak events. This is the results in the HS log
Oct-25 11:17:13 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:12 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:11 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:10 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:09 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:08 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:07 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:06 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:05 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:04 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:03 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:02 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:01 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:17:00 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:59 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:58 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:57 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:56 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:55 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:54 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:53 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:52 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:51 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:50 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:49 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:47 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:46 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:46 AM TTS Speak: (TRA-SPKR:*):Good morning. The time is now 11 o'clock. The current outside temperature is 77 degrees.
Oct-25 11:16:46 AM AirplaySpeak INFO (FMR_SPKR,COM-SPKR): Good morning. The time is now 11 o'clock. The current outside temperature is 77 degrees.
Oct-25 11:16:45 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:45 AM AirplaySpeak INFO (COM-SPKR,FMR_SPKR): c:\wave\chime2.wav
Oct-25 11:16:45 AM Event Event Anouncement Hourly Chime & Tempeture triggered by the event page 'Run' button.
Oct-25 11:16:44 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:43 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:42 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:41 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:40 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:39 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:38 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:37 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:36 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:35 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:34 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:33 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:32 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:31 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:30 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:29 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:28 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:27 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:26 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:25 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:24 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:23 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:22 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:21 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:20 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:19 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:18 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:17 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:16 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:15 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:14 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:13 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:12 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:11 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:10 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:09 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:08 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:07 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:06 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:05 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:04 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:03 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:02 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:01 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:16:00 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:59 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:58 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:57 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:56 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:55 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:54 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:53 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:52 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:51 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:50 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:49 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:48 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:47 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:46 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:45 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:44 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:43 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:42 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:41 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:40 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:39 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:38 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:37 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:36 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:34 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:33 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:32 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:31 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:30 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:29 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:28 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:27 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:26 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:25 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:24 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:23 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:22 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:21 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:20 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:19 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:18 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:17 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:16 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:15 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:14 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:13 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:12 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:11 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:10 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:09 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:08 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:08 AM TTS Speak: (TRA-SPKR:*):Good morning. The time is now 11 o'clock. The current outside temperature is 77 degrees.
Oct-25 11:15:08 AM AirplaySpeak INFO (FMR_SPKR,COM-SPKR): Good morning. The time is now 11 o'clock. The current outside temperature is 77 degrees.
Oct-25 11:15:07 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:07 AM AirplaySpeak INFO (COM-SPKR,FMR_SPKR): c:\wave\chime2.wav
Oct-25 11:15:07 AM Event Event Anouncement Hourly Chime & Tempeture triggered by the event page 'Run' button.
Oct-25 11:15:06 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:05 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:04 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:03 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:02 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:01 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:15:00 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:59 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:58 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:57 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:56 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:55 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:54 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:53 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:52 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:51 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:50 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:49 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:48 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:47 AM AirplaySpeak DEBUG 59 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:46 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:45 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:44 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:43 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:42 AM AirplaySpeak DEBUG 49 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:41 AM AirplaySpeak DEBUG 113 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:40 AM AirplaySpeak DEBUG 112 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:14:39 AM AirplaySpeak DEBUG 29 Speaker.OnCheckStatusTimerEvent() gets the lock
Oct-25 11:12:50 AM Web Server Web Server authorized login successful from: 173.163.236.99 User: edw
Oct-25 11:06:13 AM AirplaySpeak INFO Resolved Service: 0025D1099DD6 - COM-SPKR - 192.168.1.205 - 1029
Oct-25 11:06:13 AM AirplaySpeak INFO Found Service: 0025D1099DD6@COM-SPKR
Oct-25 11:06:10 AM AirplaySpeak INFO Lost Service: 0025D1099DD6@COM-SPKR
Oct-25 11:00:01 AM TTS Speak: (TRA-SPKR:*):Good morning. The time is now 11 o'clock. The current outside temperature is 69 degrees.
Oct-25 11:00:01 AM AirplaySpeak INFO (FMR_SPKR,COM-SPKR): Good morning. The time is now 11 o'clock. The current outside temperature is 69 degrees.
Oct-25 11:00:00 AM AirplaySpeak INFO (COM-SPKR,FMR_SPKR): c:\wave\chime2.wav
Oct-25 10:49:33 AM AirplaySpeak INFO Resolved Service: 0025D1099DD6 - COM-SPKR - 192.168.1.205 - 1038
Oct-25 10:49:33 AM AirplaySpeak INFO Found Service: 0025D1099DD6@COM-SPKR
Oct-25 10:49:32 AM Event Event Trigger "Lighting Kitchen Light OFF"
Oct-25 10:49:30 AM AirplaySpeak INFO Lost Service: 0025D1099DD6@COM-SPKR
Oct-25 10:41:11 AM AirplaySpeak INFO Resolved Service: 0025D1099DD6 - COM-SPKR - 192.168.1.205 - 1029
Oct-25 10:41:11 AM AirplaySpeak INFO Found Service: 0025D1099DD6@COM-SPKR
Oct-25 10:41:08 AM AirplaySpeak INFO Lost Service: 0025D1099DD6@COM-SPKR
Oct-25 10:28:15 AM Event Event Trigger "Lighting Kitchen Light On"
Oct-25 10:15:00 AM Log Info The log database is currently 5.99MB in size.
Oct-25 10:15:00 AM Log Maintenance 38 records, selected by date/time, were removed from the log database.
Oct-25 10:00:01 AM TTS Speak: (TRA-SPKR:*):Good morning. The time is now 10 o'clock. The current outside temperature is 69 degrees.
Oct-25 10:00:01 AM AirplaySpeak INFO (FMR_SPKR,COM-SPKR): Good morning. The time is now 10 o'clock. The current outside temperature is 69 degrees.
Oct-25 10:00:00 AM AirplaySpeak INFO (COM-SPKR,FMR_SPKR): c:\wave\chime2.wav
Oct-25 9:47:57 AM AirplaySpeak INFO Resolved Service: 0025D1099DD6 - COM-SPKR - 192.168.1.205 - 1031
Oct-25 9:47:57 AM AirplaySpeak INFO Found Service: 0025D1099DD6@COM-SPKR
Oct-25 9:47:55 AM AirplaySpeak INFO Lost Service: 0025D1099DD6@COM-SPKR
Oct-25 9:25:33 AM AirplaySpeak INFO Resolved Service: 0025D1099DD6 - COM-SPKR - 192.168.1.205 - 1028
Oct-25 9:25:33 AM AirplaySpeak INFO Found Service: 0025D1099DD6@COM-SPKR
Oct-25 9:25:31 AM AirplaySpeak INFO Lost Service: 0025D1099DD6@COM-SPKR
Oct-25 9:06:00 AM Energy DB Info All energy database compacting routines completed.
Oct-25 9:06:00 AM Energy DB Info No Records. Vacuuming database to condense.
Oct-25 9:06:00 AM Energy DB Info Energy database compaction initiated.
Oct-25 9:00:01 AM TTS Speak: (TRA-SPKR:*):Good morning. The time is now 9 o'clock. The current outside temperature is 50 degrees.
Old October 25th, 2016, 06:56 PM
Rvtravlr's Avatar
Ed,
In re-reading my post about router settings, I realize that I forgot to add that Multicast Rate should be Auto on the WAN side.
Also, on the LAN side, enable Multicast routing (IGMP Proxy) and enable efficient multicast forwarding (IGMP Snooping).
Michael
Old October 26th, 2016, 12:27 AM
Rvtravlr's Avatar
Spud,
What router and AirPlay speakers do you use? Do you have delays?
Michael
Old October 28th, 2016, 10:48 AM
Bump
Any input Spud?
Ed
Old October 30th, 2016, 06:10 AM
Any Idea's
Spud,
Have you looked at the log info and do you have any thoughts on what is going on?
Ed
Old October 30th, 2016, 02:44 PM
spud's Avatar
Moderator
Spud,
Ed
sorry for the delay
it looks like at some point the plugin fails to disconnect from the speaker after a TTS. That's why you see the OnCheckStatusTimerEvent being logged continuously.
Could you
- enable the "Log to File" feature and set the level to Debug.
- unplug all your airplay speakers but one
- restart the plugin
- then run your system normally and wait until the OnCheckStatusTimer is being logged continously
then send me the log file
thanks
Old October 30th, 2016, 03:14 PM
Log
Here you go. This is with 1 iHome IW3 speaker active.
Ed
Old October 30th, 2016, 05:14 PM
spud's Avatar
Moderator
Ed
There is nothing wrong in this log. Did you get the problem while recording this?
I need one where the OnCheckStatusTimerEvent log lines keep showing up and never stops unless you stop the plugin.
Old November 1st, 2016, 12:43 PM
I do not know why
I do not know why the problem persists, Perhaps it occurs when more than one speaker is in use?
Ed
Old November 2nd, 2016, 10:55 AM
spud's Avatar
Moderator
Ed
Can you confirm that you never get the problem when using only one speaker?
If so, please test with 2, and send me your log file as soon as OnCheckStatusTimerEvent log lines keep showing up and never stop.
20sec delay after the first command linksbox Insteon Plug-in (Mark Sandler) 6 October 14th, 2014 09:59 PM
Listening for command while TTS Speak jkusanovic HS2 / HSPRO 5 December 30th, 2011 12:18 PM
Neo voice changes in Speak Command pp HomeSeer Voices 5 December 4th, 2006 06:03 PM
Delay between attention acknowledgement and command readiness DanWheeler HomeSeer General Discussion Area 14 November 21st, 2004 04:21 AM
