Go Back   HomeSeer Message Board > Audio / Video and Infra-red (IR) Plug-ins > Audio / Video and Infra-red (IR) Discussion > AirplaySpeak
AirplaySpeak This plug-in is a Speak Proxy which allows Homeseer to route annoucements to AirPlay capable devices such as an AirPort Express
Old October 26th, 2016, 11:38 PM
Rvtravlr's Avatar
Rvtravlr Rvtravlr is offline
Changing voices
Is there a way to change the voice in an event?
Michael
Old October 27th, 2016, 12:25 AM
rprade's Avatar
rprade rprade is offline
Michael
Yes, you use SAPI tags such as
<voice required="name = Microsoft David Desktop">The house lights will turn off in ten minutes
within the speech text using any of the installed voice names.
Randy Prade
Aurora, CO
Prades.net
ITguyHS ITguyHS is offline
If your HS server is windows, this will change it just for this event:
<voice required="name = Microsoft Sam"> This is Home sear speaking
Be sure to spell the voice exactly as it exists in your system. [My misspelling of Homeseer is intentional. It makes HS pronounce it more properly.]
Fred
HomeSeer Pro 3.0.0.318, HS3Touch 3.0.0.68, Zwave 3.0.1.87, Envisalink DSC 3.0.0.33, WeatherXML, Z-stick, CM15A 3.0.0.8, HS phone, Way2Call
Old October 27th, 2016, 12:30 AM
Rvtravlr's Avatar
Thank you for the responses.
I tried the settings suggested and no joy.
In Win7 control panel I only see Anna.
In AirPlay Speak,p I can choose Anna, Allison or Damien.
Allison and Damien are Cepstral voices.
I wanted to change the voice on certain events to Damien for Halloween.
Michael
Old October 27th, 2016, 01:04 AM
You might try it as "Cepstral Damien". There seem to be some strange things that happen with the Cepstral voices not showing even though they're installed, but evidently you can get them to work at least in some parts of HS3. Try as a forum search on "cepstral voices". If you're running on Windows 10, see this post for how to see all the installed voices. http://board.homeseer.com/showthread.php?t=181553 OOps, never mind - I missed where you said Window 7.
Old October 27th, 2016, 08:23 AM
spud's Avatar
spud spud is offline
Moderator
for the tags to work with AirplaySpeak you have to add a special setting in AirplaySpeak.ini
[TTS]
use_sapi=True
see this thread:
http://board.homeseer.com/showthread...28#post1157328
Old October 27th, 2016, 07:58 PM
Rvtravlr's Avatar
Thanks - that worked.
Changing Voices neiltimms HSTouch™ 0 November 29th, 2008 11:41 PM
Changing voices on the fly (Rupp?) jackpod HomeSeer General Discussion Area 8 September 8th, 2008 08:21 PM
Changing Voices Spectrum HomeSeer Phone 2 July 3rd, 2007 09:23 AM
NeoSpeech and Asian voices / Fun voices GenevaDude HomeSeer Voices 5 December 29th, 2003 08:16 AM
Changing between AT&T Voices jay HomeSeer Voices 9 July 7th, 2002 12:21 PM
