Go Back   HomeSeer Message Board > Audio / Video and Infra-red (IR) Plug-ins > Audio / Video and Infra-red (IR) Discussion > AirplaySpeak
AirplaySpeak This plug-in is a Speak Proxy which allows Homeseer to route annoucements to AirPlay capable devices such as an AirPort Express
Old June 16th, 2017, 10:29 AM
Malosa's Avatar
Malosa Malosa is offline
Super Seer
Airplay stops speaking during long message
I did try a long message but it stops speaking after some words..
i attached the debug log
I hope you can fix it , because it works normal , bu only when it needs to speak a long message it stops speaking.
Its a different error than last time.
HS3Pro 3.0.0.435 on windows 7 ultimate X64 on hp quadcore laptop 8 GB. 687 Devices, 480Events
Old June 18th, 2017, 11:25 AM
Malosa's Avatar
Super Seer
Any idea ?
Old June 19th, 2017, 10:31 AM
spud's Avatar
spud spud is offline
Moderator
in your logs, the long message is that the one beginning with "initializing Network diagnostics..." ?
If so, this message starts to play at 16:23:18, but one second later another message is sent "Warning. Unauthorized device 192.168.0.51 has joined the network", maybe this subsequent is messing things up. Can you try to play only one long message with nothing after.
Old June 20th, 2017, 12:52 PM
Malosa's Avatar
Super Seer
hi Spud ,
i created a new log file without the other speech, it does still the same ,
here the log again.
at the text iphone5 it stops speaking.
Thanks for the reply.
Old June 24th, 2017, 04:33 AM
Malosa's Avatar
Super Seer
hi Spud,
any news on this problem?
Regards
Old July 5th, 2017, 11:43 AM
Malosa's Avatar
Super Seer
Hi Spud,
maybe you forget to check, but i need to know sure if my device is not working correct.
regards
Old July 18th, 2017, 01:55 PM
Malosa's Avatar
Super Seer
Bump
Old July 19th, 2017, 02:07 PM
spud's Avatar
Moderator
sorry for the delay
I tested your exact message with my Airport Express, and it worked as expected. So it must be some kind of timing issue specific to to your device.
Your second log file does not show the interesting part, i.e what happens after Speaker.OnCheckStatusTimerEvent()...
Also how do you start the speak action?
Don't you have an action event that stop the Airplay device after the Speak action? In this case you need a wait action between the 2.
Old September 15th, 2017, 01:43 PM
Malosa's Avatar
Super Seer
Hi spud
I make a Manual event. and add the text with the Dev value in there and it looks like this when it speaks:
initializing Network diagnostics . . .   multiple device's found . .  ipad 4 OnlineFor 4 days, 2 hrs, 32 mins, 12 secs..... second device .. Dell laptop OfflineFor 20 hrs, 20 mins, 47 secs .... Third device .. Iphone 5 OnlineFor 4 days, 2 hrs, 32 mins, 12 secs .. fourth device .. toshiba laptop OnlineFor 1 mins, 42 secs .. fifth device .. Audi q7 sensor OnlineFor 4 days, 2 hrs, 32 mins, 12 secs .. sixt device .. CS Server OfflineFor 3 hrs, 9 mins, 8 secs .. Diagnostics complete , found multiple devices connected to internet .. entering status mode
But if it reads at Third device .. Iphone 5 it stops.. it looks like till iphone 5 is the max it can transfer to talk.
Regards
sorry for the delay
Speaker stops speaking petez69 HS3 / HS3PRO Discussion 10 March 8th, 2017 06:18 PM
Speaking caller ID via airplay speakers infrared photoman HomeSeer Phone 1 July 2nd, 2016 09:32 PM
HS Speak just stops speaking glacket HS3 / HS3PRO Discussion 14 January 17th, 2016 03:18 PM
Best Method for Long Message strings itanic LEDAM Plug-In 2 May 17th, 2005 11:21 PM
