Building a new HS3 system wiith new computer but having issues with the install of this plugin (did have it working in HS2 on a different system). After downloading and enabling the plugin, I'm trying to set the com port [COM12] but I can't seem to open it. Nothing happens when I select the "open" button on the status screen.
I've confirmed that the port is correct and it is open. When I restart HS3, I get a popup message about registering the plugin (same issue with the BLLED plugin). I've tried to...
1. Shutdown HS
2. Go to the Data\BLAB8SS\Registration folder under your HS folder and execute the MSCommControl.reg file as an administrator.
3. Restart HS
But the issue remains. Turned on debug but not much appears in the log. Any help would be appreciated.
1. Shutdown HS
3. Restart HS
