I need some help with getting BLLock finished.
I do not have my locks setup in HS3 yet so I will need someone with one or more locks to run the attached script and attach the output to this thread.
Follow these steps:
1. Extract the attached script to your scripts folder under your HS root folder (eg: C:\Program Files (x86)\HomeSeer HS3\scripts)
2. Go to the Control Panel
3. In the Immediate Script Command box, type the following and click Execute Command.
If everything works there will be a file in your HS root folder called "HS3_Display_ZWave_Lock_Device_Info.log"
Attach this file to this thread and tell me how many locks you have in your HS3 system.
I also need this info for each different lock:
Manufacturer
Model
Type (deadbolt or lever)
Is Motorized (if the lock motorized - can u operate the lock without having to manually do it)
Follow these steps:
&hs.RunScript("HS3_Display_ZWave_Lock_Device_Info.vb", False, False)
Manufacturer
Model
