Below is my simple script that I have been using for years for HS2 with some minor mods to adapt it to HS3. I am getting this error:
Running script blSpeech_PreSpeak_3.vb :Exception has been thrown by the target of an invocation.->Does entry point Main exist in script? at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor) at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Obj ect obj, Object[] parameters, Object[] arguments) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at A.c17b105f989efe61e5979e67bec1ef734.cffd66cb0782c50126727e3f a75582d7a()
What am I missing here???
Public Sub Main(Parm As Object)
hs.SetVoice("VW Kate 16K")
Select Case hs.DeviceValue("R50") ' amnnounceType
Case 0 'no speakers or intercom (sound is local only)
Case 1 'inside speakers and intercom inside
hs.RunScriptFunc("sendSG_ASCII_3.vb", "Main", "RY02||ON", True, False) 'intercom on
hs.SetDeviceValue("G5", 0) ' inside speakers on
Case 2 'inside and outside speakers and intercom (ALL ON)
hs.RunScriptFunc("sendSG_ASCII_3.vb", "Main", "RY03||ON", True, False) 'intercom door on
hs.SetDeviceValue("G4", 100) ' outside speakers on
End Select
End Sub
End Select
End Sub
