Go Back   HomeSeer Message Board > Audio / Video and Infra-red (IR) Plug-ins > Audio / Video and Infra-red (IR) Discussion
Old June 1st, 2018, 10:10 AM
dchramcow dchramcow is offline
Seer Plus
Looking for an Audio matrix switchers from 8x8 and up compatible with HomeSeer
Hello HomeSeer forums,
So I've been working the past couple of days on finding a suitable audio solution for large homes (+8 physical inputs and 8+ Zones) that's fully compatible with HomeSeer via a plugin/script.
I've looked around several threads here, and there are some very formidable solutions out there, like Russound's MCA88X, HTD's MCA66 and the XAP800 by ClearOne, those three have plugins available, which is great.
But both the Russound and HTD ones seem to be limited to just ~6 inputs max (expansion options are only for adding outputs not inputs, at least that's what I'm understanding reading their user guides).
The ClearOne XAP800 seems like a perfect fit for what we're looking for, with its 12 inputs and 12 outputs, but unfortunately the product is EOL.
So my question to you guys is:
Is there a modern audio matrix solution for large homes that's fully compatible with HomeSeer via a plugin/script?
Thanks, have a great day guys.
Old July 4th, 2018, 11:33 AM
Seer Plus
bump ):
Old July 4th, 2018, 12:08 PM
Tomgru Tomgru is offline
Seer Master
I'm just mostly curious why you would need 8 inputs these days?
Old July 5th, 2018, 05:27 PM
DSteiNeuro DSteiNeuro is offline
Seer Master
Location: Audrey Land (Somewhere near San Diego CA USA)
It looks like this might do want you want
AudioControl M6800
AudioControl
DSteiNeuro
HS3Pro
MSI Cubi Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz, 2201 Mhz, 2 Core(s), 4 Logical Processor(s) 16GB DDRl RAM
Enabled Plug-Ins
BLRussound, BLSpeech, HSTouch Server, JowiHue, MyQ, Nest, Rain8, Squeezebox, Ultra1Wire3, UltraGCIR3, Vista Alarm, X10,Z-Wave
Old July 5th, 2018, 05:46 PM
S-F's Avatar
S-F S-F is offline
OverSeer
Quote:
AudioControl M6800
AudioControl
That thing looks like a beast!
Quote:
Originally Posted by rprade View Post
Old July 5th, 2018, 05:52 PM
Monk's Avatar
Monk Monk is offline
Seer Master
Indeed!
This just seems to have materialized from nothing - but worthy of investigation.
Old July 5th, 2018, 06:34 PM
Seer Master
Quote:
Originally Posted by Monk View Post
Indeed!
I saw it just by chance as an ad in the current CEPro magazine. I bet it is $$
I am pretty happy with my Russound 8x8. I have all of the inputs assigned but really only use a couple. I use a mixer to mix in HomeSeer Voice alerts over the music input (I mute the music and send the Voice Message using BLRussound and BLSpeech). Works great but I got sick of the voice messages and have it turned off
I have 10 output zones. I split 2 of the zones using an A/B switch to get 10 out of the 8.
Old July 6th, 2018, 07:51 PM
Monk's Avatar
Seer Master
What model Russound ?
HTML code is Off
HomeSeer Spoken Audio As A HTD Lync 12 Audio Source? jeanv UltraHTDAudio3 HSPI 4 January 14th, 2018 12:20 PM
Matrix Creator and Matrix Voice jrfuda General Home Automation Hardware Discussion 4 March 31st, 2017 07:29 PM
Updated HomeSeer Store Lighting Matrix? Rockers? UPB? TechnoCat Lighting & Primary Technology Discussion 7 May 27th, 2010 02:02 PM
cheap matrix video switchers madmax HomeSeer General Discussion Area 16 June 26th, 2005 09:31 PM
audio matrix options? collegeboyslive Audio / Video and Infra-red (IR) Discussion 19 May 10th, 2004 04:59 PM
