Autostart Homeseer on Linux
    #31
    Auto mator
      #32
      Back to the original topic for a moment...
      I've used this template script: https://github.com/fhd/init-script-t...aster/template (docs here https://github.com/fhd/init-script-template).
      For me, variables as follows:
      dir="/opt/HomeSeer"
      cmd="./go"
      user="root"
      Then:
      chmod u+x /etc/init.d/homeseer
      update-rc.d homeseer defaults
      The advantage of this script is that it logs the terminal output to a standard location - /var/log/homeseer.log / .err
        #33
        Originally posted by ARA View Post
        I'm still curious about your original error message.
        -A
        (code=exited, status=210/CHROOT)
        This is systemd complaining that you are changing the working directory without providing a user. If you specify a working directory you also need to specify a user. The simplest solution is to leave out the working directory line.
        So this service file works (assuming you have the homeseer directory in the default location of: '/usr/local/HomeSeer'):
        [Unit]
        Description=HomeSeer Home Automation Server
        After=network.target
        [Service]
        ExecStart=/usr/local/HomeSeer/autostart_hs &
        Restart=on-failure
        [Install]
        WantedBy=multi-user.target
        HTH
        Adeux
          #34
          Still stuck with HS4 AutoStart function....
          Tried...
Name:	Screenshot from 2020-05-25 11-31-57.png
          Then tried....
Name:	Screenshot from 2020-05-25 11-34-02.png
          I have this...
Name:	Screenshot from 2020-05-25 11-35-11.png
          I know HomeSeer is not installed to in the typical folder but, I'm trying to understand the adjustments I need to make.
            #35
            Here not running a service for starting Homeseer 3 or 4 in Linux.
            Rather just running a Cron job to start it and using Homeseer 3/4 GUI to shut it down. I did at one time run HS as a service.
            I run this to start Homeseer on boot with Ubuntu.
            sleep 120 && exec sh /opt/HomeSeer/autostart_hs
            Bash autostart_hs is the same as the bash go file.
            I also keep HS in the /opt/HomeSeer directory.
            Also configured a Windows Virtual Box to run multiple instances of speaker dot exe after HomeSeer starts.
            Auto mator
              #36
              Any issue with HS in a different directory? If so, what is best method to move to /opt/HomeSeer?
              Trying to run above 'sleep 120 && exec sh /opt/HomeSeer/autostart_hs' in StartUp Applications but, even when I change /opt/HomeSeer/ to /Public/HomeSeer/ it still doesnt work. Is this supposed to open a Terminal window?
                #37
                The screen package isn't installed by default. You'll need to install:
                sudo apt-get -y install screen
                  #38
                  No. Autostart_hs is the same as the /HomeSeer/go bash script.
                  type sudo exec sh /opt/HomeSeer/autostart_hs
                  at a terminal window
                  Yes as zwolfpack mentions above install screen for running the one liner above in an SSH session with "&&"
                  screen command in Linux provides the ability to launch and use multiple shell sessions from a single ssh session.
                  Auto mator
                    #39
                    Got it to work when I installed screen. HS seems to start as a service with no Terminal Window required.
                    Thank you!
                      #40
                      Yes when you run it in a service or cron job no remote terminal window is required.
                      The original Homeseer Zee ran a one liner at the end of the start up script from the /usr/local/HomeSeer directory.
                      I just mentioned running it from a terminal window to test it out. Really after it starts the only way to see it running is via the HomeSeer GUI or looking at top or htop.
                      Auto mator
                        #41
                        Right, it's a throwback to the days before windowing systems, it allowed a single dialup line to run multiple sessions. Of course the user would have to mentally keep track of what was running on each 'screen' -- what a headache!
                        Thankfully by the time I started on UNIX/UNIX-like systems (late 1980's), they were windowing systems (pre-dating MS Windows). I recall trying out screen sometime in the 1990's and quickly deciding its days of glory had passed.
