CurrentCost plugin beta 1.0.0.61
    Re: CurrentCost plugin beta 1.0.0.61
    The batteries in the sensors
      That data is not in the XML output so no you can't, they should last a good few years though.
        Same isue here
        This version did`nt help me, my grafs is still wrong.
        Current Cost 1.0.0.61:
        Homeseer 2.5.0.60
        What can I do?
          My Hometroller Pro had started to hang (power cycle only was to restart) soon after installing the plug-in circa early 2012. A few months ago I gave up, disabled the plugin and my Hometroller has returned to stability. I can't say 100% the plug-in was the culprit but seems pretty likely. Nothing was ever seen I the logs. Does the beta have any chance of resolving that problem?
          2.5.0.52 homeseer
          1.0.0.60 plug in
          -rick
          -Rick
            Feature Request
            Originally posted by technerd View Post
            Please add the ability to specify the meter read date. The graphs and data do not have any meaning if your meter is read middle of the month like most mesh network meters in the south.
            Would also like to see this option
              #21
              +1 as well...
              Furthermore, keep this pluging alive for HS2 users.
                #22
                Originally posted by renaatdb View Post
                Same isue here
                Homeseer 2.5.0.60
                What can I do?
                Did you get it to work?
                I cant still not use this plugin
                Is there a another plugin i can use?
                I use Current Cost Envi Plugin (3rd Party) to mrhappy, but he dont support the plugin anymore
                  #23
                  Current Cost on HS3
                  Hi, i'm using (well trying to get it to work at least) the Current Cost plugin v3.0.0.9 on HS3 with data input from script.
                  see: http://board.homeseer.com/showthread...t=current+cost
                  I know this thread is about another version but any help would be appriciated.
                    #24
                    Installer
                    I tried to install the plugin but the msi file says "HomeSeer is not installed"
                      #25
                      Do you have HS2 installed? That plugin is for HS2 not HS3.
                        #26
                        Ok, I have last version of HS3 and version 3.0.0.9 of CurrentCost plugin.
                        I opened 2 threads for problems with charts and currentcost_history
                        http://board.homeseer.com/showthread.php?t=166558
                        http://board.homeseer.com/showthread.php?t=166557
                          #27
                          Did you put in Bugzilla tickets on these issues?
                            #28
                            Since you guys are working on this plugin again. Is there any chance of getting tiered pricing integrated? EG: kwh 0-255=$0.13 kwh 256-600=$0.27?
                              #29
                              I would purchase this plug-in if it could do tiered pricing.
                              Ronnie
