Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Ultra Scripts and Plug-Ins > UltraPioneerAVR HSPI
UltraPioneerAVR HSPI Discussion area for the UltraPioneerAVR HSPI supporting the Pioneer AVR Receivers.
  #21
Old April 7th, 2014, 10:33 AM
huggy_d1's Avatar
huggy_d1 huggy_d1 is offline
UltraPioneerAVR HSPI - Support for 22 New 2012 and 2013 Pioneer Receivers
R/UJ,
Is it possible to allow us to *add* commands that are available in the
IR remote and can be sent via IP to command the device? I see in the
protocol spec there is a way to embed any IR code in an IP command ---
or --- are you already doing that?
If we can get the IR codes, we can pretty much use your plug-in to
control the Pioneer equipment. We just blindly send commands. Maybe
there is a clean way to monitor for feedback of custom hex commands sent
in place of IR remote buttons.
I know I get a little burned every time I have to grab an IR remote
instead of having it programmable in HSTouch using your plug-in. Not
your fault Pioneer did not make them native ip / 232 control commands,
but they did extend it with the IR hex command option.
huggy_d1
Automating made easy
  #22
Old April 7th, 2014, 10:37 AM
Ultrajones's Avatar
Ultrajones Ultrajones is offline
Huh? Where is this IR hex command option documented? What commands are available via the remote that are not available via the plug-in?
  #23
Old April 7th, 2014, 04:57 PM
huggy_d1's Avatar
http://www.pioneerelectronics.com/PU...ainment-Custom
-Install/IR+Codes/A+V+Receivers
/PUSA/Support/Home-Entertainment-Custom-Install/RS-232+&+IP+Codes/A+V+Re
ceivers
/A181AFBC/RU
Example command to Power ON/OFF just like the IR remote
/A184FFFF/RU is the UP arrow
/A187FFFF/RU is LEFT
/A181AFEF/RU is ENTER
/A186FFF/RU is RIGHT
/A185FFF/RU is down
/A181AFB9/RU is pop-up menu
I do not know how many will work as is, but this is a common option on
Pioneer IP/RS232 control.
Maybe it is simply undocumented.
If it works or is not supported, it returns "R". If it returns "E04",
it definitely did not work.
If "E04" is received, it means key lock is on. To enable commands when
in key lock, commands 99RJ, PL, ST, SF, SR, NF, and NR are supposed to
allow RCU codes (if they are supported).
  #24
Old April 8th, 2014, 07:49 AM
sparkysar sparkysar is offline
Originally Posted by Ultrajones View Post
Sorry, for clarification the RS232 protocol is what is used via the Ethernet connection. If the Android application can turn the receiver on/off, then so can the UltraPioneerAVR plug-in. I would just need to add the receiver to the supported list. Can you confirm?
Hi
You were correct the 823 was only partialy compatible and would not operate under the 2013 android Icontrol as described. I got the 1028 works well only thin that may need tweaking is the Sat/ Cable funtion does not show in the list of master functions
I registered your Plugin for HS3 last night
Thanks.
  #25
Old May 8th, 2014, 11:55 AM
vjnexus vjnexus is offline
I have a Pioneer vsx-1022k that has been working (mostly) with the plugin for some time. My question is whether it's possible to manually add more 'input' devices to the dropdown in the device for inputs. I see a slew of inputs available, and inspecting them I see each has an associated value. My problem is that 2 of the inputs I use are not listed in here, and their values are skipped. For example the input 'Game' on my receiver shows a value of 6 when I check the device in HS2pro, but it shows no name in the dropdown and I am therefore unable to select it via the plugin. This value is skipped when I inspect the values of all the dropdowns. Is there a way to either manually add this, or force a value of 6 via a script or editing a config file or something of that nature. (It may not be 6, I am not at home right now, but I seem to remember that). I am using the HS2 version of the plugin. Any feedback is appreciated.
  #26
Old May 10th, 2014, 11:07 AM
Ultrajones's Avatar
Your receiver isn't listed in the Pioneer 2011 model year API documentation. What values are missing?
  #27
Old June 1st, 2014, 12:14 PM
I went through and compared all the input of the receiver to those listed in the input dropdowns. The ones that are missing are Sat/Cbl - value 6, and Game - value 49.
Some of the others the inputs don't quite match the names but that is still useable.
  #28
Old June 1st, 2014, 02:48 PM
Ultrajones's Avatar
The input 06 - SAT/CAB was new with the 2012 receivers. I don't see 49 in any of the Pioneer API documentation. Is your receiver connected via serial or network? If it is connected via network, was it auto discovered? And if yes, is the make/model reported as VSX-1022?
Once I add the VSX-1022 as a valid model, it will configure the input "06 - SAT/CAB" when the input device is created. I am a bit confused on the input 49 though. I am still trying to find where this is documented ...
  #29
Old June 1st, 2014, 03:20 PM
It has been so long since I got it working it's hard to remember. I do remember it was difficult to setup and I think I had to manually enter the model and mac address...? Honestly I don't remember. I know I had to set the ip address to use port:8102. It is showing model VSX-1022 and is connected via the network.
  #30
Old July 3rd, 2014, 11:18 AM
Anything further on getting the inputs on a vsx-1022?
  #31
Old July 3rd, 2014, 12:16 PM
Ultrajones's Avatar
From the Receiver tab, edit the entry for your VSX-1022 and change the model to VSX-1023, then restart HomeSeer2. You'll then need to delete the input device and re-create it which will rebuild the inputs based on the list of valid Pioneer receiver 2012 inputs.
I am still reluctant to add any type of support for Game - value 49 as input 49 in not listed in any of the Pioneer API documentation.
Ultrajones
  #32
Old December 9th, 2014, 04:48 AM
VirtualPanther's Avatar
VirtualPanther VirtualPanther is offline
Ultra,
I know someone has already asked about support for Pioneer VSX-823. I have a variation of that (http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1). It is connected to my LAN and I am able to control it successfully with Roomie Remote app on my iPhone. I have not tried anything fancy, but turning on and off, changing volume, and switching sources definitely works. Roomie lists a variant of this receiver, VSX-823-K, on their supported devices page, under IP control section: http://www.roomieremote.com/device-compatibility/
  #33
Old December 21st, 2014, 01:01 PM
wolf382's Avatar
wolf382 wolf382 is offline
VSX-70 and missing control for HDZone
Hi- I have the VSX-70 and it is setup to use the HDZone. So I have a Main Zone,HDZone and Zone2. I do not see a way to control the HDZone from the plugin/devices. I tried using the other zone settings but they do not control the HDZone from what I can tell. Can you add that option or is it here and I am just missing it?
thanks
Update. i figured it out.It uses Zone 4 for the HDZone.I just needed to edit the source name under the device.
  #34
Old January 23rd, 2015, 12:45 PM
Question
I *really* like my Pioneer VSX-1123 and I know the plug-in has a lot of feature. I cannot comment on the Denon AVR-2313CI or the "other plug-in" because I have never used them.
Ultrajones
Ultra!
Given your experience, what would be your receiver of choice right now? I am using Pioneer VSX-823, which is not compatible with this plugin. It is also giving me a ton of headaches controlling it via Global Cache IP-to-IR. I want to move it to my kid's play room and get something better for this movie room. What would you go with? I only need the main zone at 5.1 channels. I do need flawless compatibility with this plugin, since this is how I will automate events. Open to suggestions...
  #35
Old January 27th, 2015, 07:21 PM
Ultrajones's Avatar
Originally Posted by VirtualPanther View Post
Ultra!
I really like my Pioneer VSX-1123-K receiver. It was inexpensive, supports 2 HDMI outputs and works great with the UltraPioneerAVR3 plug-in. Any of the 2013 receivers should work ...
"SC-79/CUXJ"
"SC-77/CUXJ"
"SC-75/CUXJ"
"SC-1523/UXJCB"
"SC-72/CUXJ"
"SC-1323/UXJCB"
"SC-71/CUXJ"
"SC-1223/UXJCB"
"VSX-70/CUXE"
"VSX-1123/CUXESM"
Ultrajones
  #36
Old January 27th, 2015, 07:23 PM
Thank you so much for sharing your experience. I will definitely look into that because I can't wait to automate my home audio video equipment.
  #37
Old January 27th, 2015, 08:59 PM
Ultra,
Do you plan to add support for the current line of Pioneer receivers (i.e. 2014)? I looked up one of those on the list from 2013 and Amazon informed me that a newer model is available...
  #38
Old February 1st, 2015, 11:51 AM
Ultrajones's Avatar
Ultra,
Yes, I'll be adding support for them when I convert the plug-in to Linux within the next month or so.
Ultrajones
  #39
Old February 1st, 2015, 01:50 PM
Thumbs up
Ultrajones
Sounds good!
  #40
Old February 7th, 2015, 12:13 PM
outbackrob's Avatar
outbackrob outbackrob is offline
How can you tell if it could work?
Ultra, Found a VSX-824 for $50. Has a crack in the front bezel but works perfectly. It will sit in a closet and no one will see it's ugliness, so I bought it.
When you are determining which models will work or partially work, what info do you need to know that? Since the 823 is not on the list, I suspect the 824 won't be either, but wanted to know how you determine it. I have my fingers crossed just in case.
I have an 1121 for the theater and it is awesome! Workhorse!
Rob
HTML code is On
