Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Ultra Scripts and Plug-Ins > UltraPioneerAVR HSPI
UltraPioneerAVR HSPI Discussion area for the UltraPioneerAVR HSPI supporting the Pioneer AVR Receivers.
  #61
Old March 21st, 2015, 09:21 AM
Ultrajones's Avatar
Ultrajones Ultrajones is offline
Originally Posted by sparkman View Post
Hi Randy, I can test it. I've sent you am email as well.
Cheers
Al
Hello Al, let's try this:
1) Connect you receiver to your local network and ensure its powered off.
2) Install the UltraPioneerAVR3 plug-in from the HomeSeer updater, then enable it.
3) From the Receivers tab, confirm the receiver is discovered and the model number is VSX-1124.
4) Now update the model number from VXS-1124 to VSX-1123, then restart the plug-in.
5) From the Receivers tab, confirm the receiver model number is still VSX-1123.
6) Power on the receiver and watch the logs to determine if it detected the powered on stated.
7) Wait about 1 minute, then visit the AVR Devices web page to determine what was detected.
At this point, everything under Master Controls, Zone2 Controls, Zone4 Controls, Channel Level, Audio Information, Video Information, Video Function, DSP Function, AMP Function, Tuner Function and Misc Function should have values. If not, try manually putting on a video source and an audio source so those value populate.
If it appears to be working at this point, then try creating devices and controlling your receiver with the HS devices that gets created. You should also be able to use the remote control and change input, volume etc. and you should see those changes reflected in the HS devices that get created.
Please report back if that works. If not, we will try plan b.
Ultrajones
  #62
Old March 21st, 2015, 10:45 AM
sparkman's Avatar
sparkman sparkman is offline
Hi Randy,
All seems to work doing that, except for step 5, the receiver model number stays at VSX-1123.
I do see some warnings in the log (each repeated 4 times):
Mar-21 8:40:14 AM	 	Warning	No response/improper response from Pioneer AVR device '192.168.1.206:23' to command '?ZEP'. Your Pioneer AVR may not support the feature 'Zone3 Power'.
Mar-21 8:40:05 AM	 	Warning	No response/improper response from Pioneer AVR device '192.168.1.206:23' to command '?RGB03'. Your Pioneer AVR may not support the feature 'Input Name Information'.
I'm assuming those are a normal part of the discovery process.
Al
  #63
Old March 21st, 2015, 11:27 AM
Ultrajones's Avatar
Hi Randy,
Al
Sorry, item #5 was a typo. I fixed it. Yes, those 2 "No response" warnings are normal for your receiver. You can disable it from the AVR Devices tab so they don't get checked again.
I'll post an update soon that adds support for the VSX-1124 model so you don't have to manually change the type from VSX-1124 to VSX-1123.
Ultrajones
  #64
Old March 21st, 2015, 11:54 AM
sparkman's Avatar
Ultrajones
Thanks Randy!
Cheers
Al
  #65
Old March 25th, 2015, 10:40 AM
jlrichar's Avatar
jlrichar jlrichar is offline
New receivers announced!
http://www.soundandvision.com/conten...equipped-av-rs
HS3 : HSpro (3.0.0.318) on Win2012 (vm on ESXi)
  #66
Old April 25th, 2015, 05:46 PM
johnnybwis's Avatar
johnnybwis johnnybwis is offline
Ultrajones,
My vsx 1121 just turned into a paper weight. So I need to get something pretty soon and am considering the vsx 1124. But I also see the new model coming out which is a vsx 1130. Pricing that I've seen seems pretty close to the same on both models so of course I would rather go with the newer version. Or is that too risky because it might not work with this plugin?
John
  #67
Old May 24th, 2015, 05:52 PM
Leoleo's Avatar
Leoleo Leoleo is offline
VSX-1130-K ?
Gurus,
My amp just went belly up and I'm looking for a replacement. I like the VSX-1123-K since it was recommended as a decent amp fully vetted with HS. I ran into the VSX-1130-K which seems similar but has Bluetooth which seems an advantage. Does the VSX-1130-K work with the UltraPioneer plugin? I looked all over and didn't see it listed specifically.
Thanks in advance,
Leo
  #68
Old May 25th, 2015, 10:00 AM
Ultrajones's Avatar
Yes, it should work with the plug-in with a simple work-around (http://board.homeseer.com/showpost.p...7&postcount=61). However, I am updating the plug-in to officially support the 2015 receivers. I'll be posting an update when done.
Ultrajones
  #69
Old July 2nd, 2015, 12:17 PM
dcdelong's Avatar
dcdelong dcdelong is offline
Just ordered a VSX-1130-k for delivery this week-end. Planning on using the work around. Will that cause any issues when the plug-in formally supports the 2015 models? If so I can wait a bit to bring it into the mix.
Chris
HSPRO3 3.0.0.368 on HP 8000, 9 SONOS, Vista p20 alarm, 3 IPads and HP Touch Screen, 22 z-Wave, 54 INSTEON
Plugins :BLBackup:,Pushover 3P:,Wiimote:Winery,HSTV:,Insteon:,PHLocation:,drhsIpPlugIn:, UltraNetatmoWelcome3:,UltraSighthoundVideo3:,Vista Alarm:,UltraCID3:,Random:,EasyTrigger:,iAutomate RFID:,FitbitSeer:,Z-Wave:,HSTouch Server:,weatherXML:,Sonos:,Restart:,UltraGCIR3:,UltraPioneer AVR3:JowiHue;WiiMote;MyQ
  #70
Old July 2nd, 2015, 12:43 PM
Ultrajones's Avatar
Chris
The version I released yesterday adds basic support for the 2014 and 2015 models. I am still going though the documentation to see what other new options I'll be adding to the plug-in.
Ultrajones
  #71
Old July 21st, 2015, 06:59 AM
Stones Stones is offline
Europe
Dear UltraJones
I´m about to invest in 4 Pioneers receivers.
I do not like Sonos and your plugin is for me a much better solution all over.
I will use the HDMI in/out connection from Pioneer for my Samsung 2015 televisions.
I will use the Airplay function for announcement and music.
In 3 rooms i don´t actually need cinema 5.1 sound but i can live with a receiver of that kind to achieve the functionality your plugin gives me other places.
The 4. room is my master bedroom and it would be nice with a little bigger workhorse.
The models we have in europe is probably kind of the same as in US but with difference model numbers.
I would like to buy new models from 2015 for this project.
Are you close with a list of models for 2015 or is there a way where I can ordre the receiver and be confident that it can be controlled by your plugin at a later state.
Ex. the rs-232 protocol or other things I can read in the spec.
I hope you can guide me in this.
Stones
  #72
Old November 30th, 2015, 11:20 AM
morrisdlx's Avatar
morrisdlx morrisdlx is offline
Seer Plus
Initial setup – huge learning curve
Hi, I am in my initial setup of all AV and home automation. I have a Homeseer S6 PRO and a Pioneer VSX-1130K. I have downloaded the UltaPioneerAV3 plugin to test before buying. I followed the recommended install steps listed at http://board.homeseer.com/showpost.p...7&postcount=61. Everything seemed to go well and after installation I have a large list of devices grouped under PAVR1 Master Controls and PAVR1 Channel Level.
As recommended I then tried to create events using the listed devices.
PROBLEM: The only devices that would respond to the events I created were Power on/off, and Mute.
Please advise, is there an additional step I am missing or a configuration change I missed?
Thank you
  #73
Old November 30th, 2015, 09:41 PM
Ultrajones's Avatar
Thank you
Hello, I assume the receiver is turned on when you're trying to control the receiver. Can you tell me if you're able to manually control the receiver using the HomeSeer devices that were created? Is there anything written to the HomeSeer log?
Ultrajones
  #74
Old December 10th, 2015, 12:29 AM
morrisdlx's Avatar
Seer Plus
UltraJones,
Sorry the slow response, I have been tied up with getting moved in. To you question, "Hello, I assume the receiver is turned on when you're trying to control the receiver. Can you tell me if you're able to manually control the receiver using the HomeSeer devices that were created? Is there anything written to the HomeSeer log?"
PWR and MUTE are working. I tried other devices with manually with no success. I also retried the events, and still can only get PWR and MUTE to work. I have clipped the log entries for your review. Please note, I have an email configuration that I will address.
Thank you for any help you can provide.
Morrisdlx
Dec-09 11:17:44 PM Error Unable to connect to POP server(1) pop3.live.com Error: authentication failed
Dec-09 11:16:56 PM HSTouch Server Debug 11:16:56:0150 ~ String change event, value is: 0
Dec-09 11:16:56 PM HSTouch Server Debug 11:16:56:0121 ~ String change event for PAVR1_listening-mode to string:AUTO SURROUND Straight Decode
Dec-09 11:16:53 PM HSTouch Server Debug 11:16:53:6523 ~ String change event, value is: 0
Dec-09 11:16:53 PM HSTouch Server Debug 11:16:53:6503 ~ String change event for PAVR1_listening-mode to string:STEREO
Dec-09 11:16:22 PM HSTouch Server Debug 11:16:22:4272 ~ String change event, value is: 0
Dec-09 11:16:22 PM HSTouch Server Debug 11:16:22:4247 ~ String change event for PAVR1_listening-mode to string:AUTO SURROUND Straight Decode
Dec-09 11:16:02 PM HSTouch Server Debug 11:16:02:3860 ~ String change event, value is: 0
Dec-09 11:16:02 PM HSTouch Server Debug 11:16:02:3840 ~ String change event for PAVR1_listening-mode to string:STEREO
Dec-09 11:10:50 PM HSTouch Server Debug 11:10:50:0460 ~ String change event, value is: 0
Dec-09 11:10:50 PM HSTouch Server Debug 11:10:50:0430 ~ String change event for PAVR1_listening-mode to string:AUTO SURROUND Straight Decode
Dec-09 11:10:33 PM HSTouch Server Debug 11:10:33:1470 ~ String change event, value is: 0
Dec-09 11:10:33 PM HSTouch Server Debug 11:10:33:1445 ~ String change event for PAVR1_listening-mode to string:STEREO
Dec-09 11:07:42 PM Error Unable to connect to POP server(1) pop3.live.com Error: authentication failed
Dec-09 11:00:57 PM HSTouch Server Debug 11:00:57:7810 ~ String change event, value is: 0
Dec-09 11:00:57 PM HSTouch Server Debug 11:00:57:7785 ~ String change event for PAVR1_listening-mode to string:AUTO SURROUND Straight Decode
Dec-09 11:00:29 PM HSTouch Server Debug 11:00:29:3157 ~ String change event, value is: 0
Dec-09 11:00:29 PM HSTouch Server Debug 11:00:29:3137 ~ String change event for PAVR1_listening-mode to string:STEREO
Dec-09 10:58:16 PM HSTouch Server Debug 10:58:16:6238 ~ String change event, value is: 0
Dec-09 10:58:16 PM HSTouch Server Debug 10:58:16:6208 ~ String change event for PAVR1_listening-mode to string:AUTO SURROUND Straight Decode
Dec-09 10:57:58 PM HSTouch Server Debug 10:57:58:4876 ~ String change event, value is: 0
Dec-09 10:57:58 PM HSTouch Server Debug 10:57:58:4866 ~ String change event for PAVR1_listening-mode to string:STEREO
Dec-09 10:57:40 PM Error Unable to connect to POP server(1) pop3.live.com Error: authentication failed
Dec-09 10:57:39 PM HSTouch Server Debug 10:57:39:0574 ~ String change event, value is: 0
Dec-09 10:57:39 PM HSTouch Server Debug 10:57:39:0544 ~ String change event for PAVR1_listening-mode to string:AUTO SURROUND Straight Decode
Dec-09 10:57:10 PM HSTouch Server Debug 10:57:10:3830 ~ String change event, value is: 0
Dec-09 10:57:10 PM HSTouch Server Debug 10:57:10:3800 ~ String change event for PAVR1_listening-mode to string:STEREO
Dec-09 10:53:21 PM HSTouch Server Debug 10:53:21:9663 ~ Value change ref:69 Address:PAVR1_main-mute NewVal: 1OldVal: 0
Dec-09 10:53:18 PM HSTouch Server Debug 10:53:18:5683 ~ Value change ref:69 Address:PAVR1_main-mute NewVal: 0OldVal: 1
Dec-09 10:52:13 PM HSTouch Server Debug 10:52:13:0556 ~ String change event, value is: 0
Dec-09 10:52:13 PM HSTouch Server Debug 10:52:13:0526 ~ String change event for PAVR1_listening-mode to string:AUTO SURROUND Straight Decode
Dec-09 10:52:12 PM HSTouch Server Debug 10:52:12:9698 ~ Value change ref:72 Address:PAVR1_listening-mode-setting NewVal: 5OldVal: 50
Dec-09 10:49:28 PM Event Event Trigger "Manage AV Vol-Down"
Dec-09 10:49:28 PM Event Event Manage AV Vol-Down triggered by the event page 'Run' button.
Dec-09 10:49:27 PM Event Event Trigger "Manage AV Vol-Down"
Dec-09 10:49:27 PM Event Event Manage AV Vol-Down triggered by the event page 'Run' button.
Dec-09 10:49:24 PM Event Event Trigger "Manage AV Vol-Up"
Dec-09 10:49:24 PM Event Event Manage AV Vol-Up triggered by the event page 'Run' button.
Dec-09 10:49:22 PM Event Event Trigger "Manage AV Vol-Up"
Dec-09 10:49:22 PM Event Event Manage AV Vol-Up triggered by the event page 'Run' button.
  #75
Old December 10th, 2015, 07:48 AM
karlito karlito is offline
hello
i want use this plugin but it writes me :
warning : failed getting interfacestatus from ultrapioneer avr3 - the interface was not found in the list of active interfaces , the list may need to be refreshed.
i dont understand why ?
i uninstalled the installed but not works
  #76
Old December 13th, 2015, 11:07 AM
Ultrajones's Avatar
UltraJones,
Morrisdlx
I am not seeing any output from my plug-in in the log data you provided.
ultrajones
  #77
Old December 13th, 2015, 11:10 AM
Ultrajones's Avatar
Originally Posted by karlito View Post
hello
From PLUG-INS > Manage > Installed Plug-ins, please confirm the UltraPioneerAVR3 license section says "Trial with n days left." or "Licensed".
Ultrajones
  #78
Old December 19th, 2015, 06:17 PM
morrisdlx's Avatar
Seer Plus
ultrajones
Ultrajones,
The above was every log entry while trying to execute pioneer devices. At this point, my trial license has expired. I would really like to be able to integrate my VSX-1130-k Pioneer receiver but, at this point I am stumped.
I have some significant network work to complete and need to work on other plugins for surveillance cameras. When this is completed, I will review the current inputs for 1130 specific installations.
Thank you for taking the time to look over my log data.
Dave
  #79
Old December 19th, 2015, 09:17 PM
Ultrajones's Avatar
Ultrajones,
Dave
The logs you provided looks like you were trying to control the UltraPioneerAVR plug-in devices by changing the device string which won't work. You have to control the plug-in devices by changing its value.
Ultrajones
  #80
Old December 21st, 2015, 12:27 PM
morrisdlx's Avatar
Seer Plus
Ultrajones
Ultrajones,
I really want to make this work. If I can get the trail license renewed, I will send a detailed step by step information on the install, tests, and results. Is there a way to refresh the trail license and try again?
Dave
HTML code is On
