I upgraded to the official .190 release of the zwave plugin and then did a secure inclusion, while battery powered, which appeared to go well in the zwave console. I only have 2 child devices, Battery and Home Security. Within this product's threads I've seen mention of people having 3 child devices. Is 2 the new normal? It appears the 1 Home Security device is setup to show if the Product Moved and if Motion Detected.
Can the LED be set to not turn on when motion is detected?
What does the setting "Enable Binary Sensor for Motion" do?
What do the "...Basic Set..." settings do?
The response time to motion seems poor. I have 4 HSM200 and 4 Insteon motion sensors for comparison. This product seems to have a bit of a delay before sending the Motion signal. Maybe .5-1 second. I base this on the blue light as well as the On command sent to a light when this sensor reports motion. The HSM200 sends the command right away and the controlled light turns on immediately. The Insteon motion sensors' LEDs also light immediately upon motion, almost too quick for me to see it. Can anything be done to make this device more responsive and send the command more quickly? I didn't see a setting for this. This is disappointing to me because I want the lights to turn on ASAP when I enter a room. I bought a 3-pack too. Do you think I can return them?
Thanks in advance for any info
