How to Reprogram a Device that has Forgotten its Links
    I have some early/old Keypad Lincs that forget their links due to power failure. HS2 knows what the links should be. Is there a way to tell the HS2 Insteon interface to reprogram ALL the links that it thinks a device should have (not just new or changed links)? And, could one cause this to happen for every device that HS knows about, not just device by device? I believe that there is a way, but I've forgotten how. Thanks!
    you can use the 'program device for homeseer' to reprogram the standard links but any custom links will have to be reprogrammed manually using the plugin.
    i would take a screen shot of the link page so you will remember what needs to be reprogrammed manually.
    Mark
    HS3 Pro 4.2.19.5
