I have been trying to use a small plug-in that mrhappy was kind enough to provide in this thread.
I am getting erratic results when using the comparison on two OneWire temperature devices on a single OWServer and using devices created by this plug-in. The plug-in operates normally on other devices.
One area of the problem is that the plug-in only creates a trigger, it will not operate as a condition. As such mrhappy has created a situation where either of the two devices changing could trigger an event. I'll try to describe the function and give my thoughts as to why it is not working.
The two devices I am comparing are a OneWire sensor that measures the tank temperature of our domestic hot water (DHW). The DHW is heated indirectly byor heating system boiler. The second sensor is the supply of hot water from the boiler to the passive heating coil.
Using the comparison provided by mrhappy's plug-in i want to trigger the event when the DHW Tank temperature is greater than the Boiler supply temperature, the goal is to capture some of the residual heat from the boiler into the DHW during certain specific conditions.
The DHW supply probe is device #13 on the OW Server. The tank temperature is device #14 on the OWServer. The owserver pdates its values on 22 devices in roughly 23 seconds, or about 1 second apart on the probes. That means that device #13 is updated about 1 second before device 14. It is clear that the OWServer updates the readings sequentially and always working through the loop from top to bottom, then starting over.
The Ultra1Wire3 plug-in updates the devices about once every 64 seconds. I have not been able to tell what order they are updated in.
What I am getting to is that there are four possible ways that the trigger from the plug-in can be configured
device 13 < device 14
device 13 > device 14
device 14 < device 13
device 14 > device 13
The only one that seems to trigger reliably is device 13 > device 14.
This leads me to several questions.
I realize that the real problem is that the comparison of two devices being being a trigger results in the probability it could trigger when one is updated and a repeat trigger when the second device is updated. My concern is that the false triggers I am seeing are on such a disparity of values in the comparison that it really cannot be due to a one minute or so delay in updating the readings from one device to the next.
- Is it possible that the Ultra1Wire3 could grab values from the OWServer mid loop?
- In what order does the Ultra1Wire 3 plug-in update its devices in HomeSeer?
- Is there any chance the Ultra1Wire3 plug-in momentarily clears the value in a temperature device just before it writes the new value?
