WGL W800USB RF Antenna Kit - Working
    Okay, I will try and focus on one issue at a time here. I purchased the WGL W800USB RF Antenna Kit along with the ACT TI 103 interface and the HSPRO software. I installed the WGL Antenna Kit and remover my RR501's and now none of my RF stuff is working. Motion Sensors specifically. Home Seer support tells me to go the this message board for assistance. I do understand Home Seer is a small company and are probably stretched pretty thin. I would very much like to make this all work. Does anyone have any suggestions regarding the WGL W800USB RF Antenna Kit and making it work with HSPRO?
    I will see if I can get some log entries on here to help. Thanks in advance.
    This is what I found in the log relating to this issue when I startewd Home Seer up just now:
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: AC-RF2 Processor, version: 1.1.3226.27426
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: ActiveBackup Plugin, version: 2.0.0.26
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: X10 CM11A/CM12U, version: 2.2.0.4
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: X10 CM15AUSB, version: 1.0.0.6
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: DSC Security, version: 2.0.0.14
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: HSTouch Server, version: 1.0.0.60
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: HSTouch Android, version: 1.0.0.2
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: HSTouch iPhone, version: 1.0.0.2
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: HSTouch Server Unlimited, version: 1.0.0.1
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: Insteon, version: 1.1.52.1
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: iTunes, version: 2.5.0.13
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: Media Player, version: 2.5.0.16
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: RainRelay8, version: 1.0.0.11
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: RCS Serial Thermostats, version: 2.4.0.7
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: RCS X10 Thermostat, version: 2.0.0.105
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: ACT TI103, version: 2.0.0.5
    12/7/2012 9:15:35 AM - Plug-In - Found plug-in: UPB, version: 1.0.2.7
    12/7/2012 9:15:36 AM - Plug-In - Found plug-in: WebCam, version: 2.0.0.2
    12/7/2012 9:15:36 AM - Startup - Initializing Plug-Ins
    12/7/2012 9:15:36 AM - Plug-In - Initializing Plug-in: Media Player
    12/7/2012 9:15:36 AM - Plug-In - Finished initializing plug-in Media Player
    12/7/2012 9:15:36 AM - Plug-In - Interface AC-RF2 Processor is running as a trial, 23 days remaining.
    12/7/2012 9:15:36 AM - AC-RF2 Processor - AC-RF2 Processor Plugin Version Release 1.1.3226.27426 Has Registered. Plugin Copyright (c) 2008 - AutomationCraft, LLC.
    12/7/2012 9:15:36 AM - Plug-In - Initializing Plug-in: AC-RF2 Processor
    12/7/2012 9:15:36 AM - AC-RF2 Processor - Device #1 Initializing - (W800RF32 receiver on Com 4)
    12/7/2012 9:15:36 AM - Media Player - MPAppThreadProc start
    12/7/2012 9:15:36 AM - Media Player - Loading library in the background, this could take a few minutes...
    12/7/2012 9:15:36 AM - Media Player - Getting track information...
    12/7/2012 9:15:36 AM - AC-RF2 Processor - The RF receiver was initialized on Com 4 - Ready to start I/O
    12/7/2012 9:15:37 AM - Warning - 'status' property on device ACRF2 Plugin ACRF2 Device Monitor was accessed - this property has been deprecated and should not be used.
    12/7/2012 9:15:38 AM - Plug-In - Finished initializing plug-in AC-RF2 Processor
    Can anyone tell me what all this might mean and how I might best proceed please? Thank you.......Mike
    Personally I do not see any issues related to the ACRF2 plugin / W800 with the log you posted.
    Try a simple test using some remote keypad or similiar with it next to the antenna, meanwhile turn on some granular logging.
    You will see the plugin/W800 chatting away.
    You can disable the message about "this property has been depreciated" on the main setup page in Homeseer.
    Disable obsolete API procedure warning messages:
    I have two W800's connected to two antennas (one in the attic and one on the main floor) and both devices and antennas work fine.
    Mostly only use it with the old x10 palm pad to manually turn on and off sprinkler zones.
      Did you configure the ACRF2 plugin via the Setup > Interfaces tab?
        Thank you Pete and Rupp-
        Yes I did configure the WGL W800USB on the interface page. That page shows the "interface ok." I will get a remote and take it ou to the garage where I placed the antenna and see if I can generate any RF. I apologize I do not know what granular logging is and I do not see on the main setup page where I would disable that obsolete message. Let you know what I find out with the remote.
          I did not have to go to the garage. In my office with the remote, I am able to see commands and the lights do respond. That tells me the WGL device is working fine but Home Seer is not seeing it. Is my assumption correct? Here is what the log said when I sent signals with the remote:
          12/7/2012 10:15:01 AM - Device Control - Command sent to 1st Floor My Office My Office Desk Lights: D1 On Dimval: 0 Data: 0
          12/7/2012 10:15:01 AM - X10 Received - D1 (1st Floor My Office My Office Desk Lights) D On
          12/7/2012 10:15:03 AM - Device Control - Command sent to 1st Floor My Office My Office Desk Lights: D1 On Dimval: 0 Data: 0
          12/7/2012 10:15:03 AM - X10 Received - D1 (1st Floor My Office My Office Desk Lights) D On
          12/7/2012 10:15:07 AM - Device Control - Command sent to 1st Floor My Office My Office Desk Lights: D1 Off Dimval: 0 Data: 0
          12/7/2012 10:15:07 AM - X10 Received - D1 (1st Floor My Office My Office Desk Lights) D Off
          12/7/2012 10:15:22 AM - Device Control - Command sent to 1st Floor My Office My Office Desk Lights: D1 On Dimval: 0 Data: 0
          12/7/2012 10:15:22 AM - X10 Received - D1 (1st Floor My Office My Office Desk Lights) D On
          12/7/2012 10:15:25 AM - Device Control - Command sent to 1st Floor Safe Light: D2 On Dimval: 0 Data: 0
          12/7/2012 10:15:25 AM - X10 Received - D2 (1st Floor Safe Light) D On
          12/7/2012 10:15:28 AM - Device Control - Command sent to 1st Floor Safe Light: D2 Off Dimval: 0 Data: 0
          12/7/2012 10:15:28 AM - X10 Received - D2 (1st Floor Safe Light) D Off
          I'm hoping that that little test with the remote provided some clue as to what the problem may be?? What should be my next step?
            By the way, I went back to that main setup page and I found where I could remove obsolete messages
              no
              If the lights went on in your office; then your W800/plugin responded to the remote control then told the CM11A to turn on and off the lights.
              Where is it you want to see that Homeseer is working with your CM11A?
              If you refresh the X10 defined variable then you will see the change from on to off or from off to on when you press your remote control.
              If you enable logging for same said variable you will also see it turn on and off.
              You could also test the range of your remote by taking an X10 chime module with you from room to room and listen for it and check your X10 CM11A signal throughout the house.
              The RR501 talks directly to the powerline such that whenever you push a button on your remote it sends out X10.
              The WGL W800 is only a receiver which talks only to its usb port.
              The WGL V572 is a transceiver. You could purchase this and connect it to a TW523 and talk to the powerline this way; similiar to your RR501.
                Thank you for getting back to me. Let me see if I can answer your questions.
                I do not have a CM11A. I am assuming that is an X10 interface of some kind? The interface I am using is the ACT TI 103 X10 Interface. As far as I can tell, it is working fine.
                I apologize, Ii'm not sure what you mean by refreshing the X10 defined variable.
                I can operate my office lights, D1 and D2 and my xmas lights D3 and D4 with the remote from anywhere in my house.(All I have is a camera remote and it only goes up to 4)
                The garage motion sensor is set to send a command of D5 ON to the X10 outlet I have at my workbench. That is working now without a RR501 being plugged in.
                Here's what does not make sense. I changed the Front Porch Motion Sensor to D7. I set the X10 Chime in my office to D7. The chime goes off when the motion sensor is tripped but only if a RR501 is plugged in. When I unplug the RR501, the motion sensor does not ring the D7 Chime in my office nor does it put a D7 signal on the powerline when I look at the log.
                I placed the antenna in the garage, high up and it is only about 6 feet from where the RR501 was plugged in. Why doesa one motion sensor work with the WGL device and the other motion sensor not?
                What am I missing or doing wrong?
                  Does the motion sensor (that doesn't work) work if you move it closer to the W800 receiver? There are several older threads on how to beef up the antenna on these. Many of use use two receivers as well to help with this issue.
                    The antenna is out in the garage maybe 5 feet from where the RR501 was plugged in. Is the antenna that weak where I need to check it? The sensor is outside the garage maybe 25 feet from the antenna. The actual receiver is in my office.
                    So if I understand you, you are thinking that maybe the current locations of the antenna and the front porch motion sensor are somehow not compatible?
                    Logically, I guess my next move has to be to change location for one or both of those components. Well, it pretty much has to be the antenna because i need the Front Porch Motion Sensor pretty much where it's at. Let me do some more checking. I shut Home Seer down and started it back up and I just walked out front into the garage. The garage motion sensor did turn on the X10 outlet set to D5 when I walked into garage and sent an OFF command when it did not detect activity for a minute. The front porch motion sensor(D7) did NOT activate the Chime in my office nor do I see any record of any activity on D7. Here's the log since the restart if that helps any. Besides illustrating that I have more than just one problem with my new system. Ha Ha.
                    12/7/2012 12:00:32 PM - Startup - Using system's regional settings
                    12/7/2012 12:00:32 PM - Startup - Creating Class Objects...
                    12/7/2012 12:00:32 PM - Startup - COM port classes started.
                    12/7/2012 12:00:32 PM - Startup - Application interface class started.
                    12/7/2012 12:00:32 PM - Startup - Web server class started.
                    12/7/2012 12:00:32 PM - Startup - E-Mail SEND class started.
                    12/7/2012 12:00:32 PM - Startup - E-Mail RECEIVE class started.
                    12/7/2012 12:00:32 PM - Startup - Z-Wave class started.
                    12/7/2012 12:00:32 PM - Startup - Plug-In Interface class started.
                    12/7/2012 12:00:32 PM - Startup - Speech recognition class started.
                    12/7/2012 12:00:32 PM - Startup - HSPhone dialer class started.
                    12/7/2012 12:00:32 PM - Startup - Loading Settings
                    12/7/2012 12:00:32 PM - Startup - Settings Loaded.
                    12/7/2012 12:00:32 PM - Startup - Current sunrise/sunset values calculated.
                    12/7/2012 12:00:32 PM - Startup - HSPhone external interface class started.
                    12/7/2012 12:00:32 PM - Startup - Local voice recognition class started.
                    12/7/2012 12:00:32 PM - Startup - Database SAVE process started.
                    12/7/2012 12:00:32 PM - Startup - Loading configuration file ...
                    12/7/2012 12:00:32 PM - System - Loading device types file...
                    12/7/2012 12:00:32 PM - Database - Opening (Mode=Read) up HomeSeer database: C:\Program Files (x86)\HomeSeer HSPRO\Config\HomeSeer2.mdb
                    12/7/2012 12:00:32 PM - Database - Loading Devices...
                    12/7/2012 12:00:32 PM - Load Config - 19 total devices loaded.
                    12/7/2012 12:00:32 PM - Load Config - Checking device type settings for all devices...
                    12/7/2012 12:00:32 PM - Load Config - Finished checking device type settings.
                    12/7/2012 12:00:32 PM - Load Config - Loading Events...
                    12/7/2012 12:00:32 PM - Load Config - 10 total events loaded.
                    12/7/2012 12:00:32 PM - Database - HomeSeer configuration database C:\Program Files (x86)\HomeSeer HSPRO\Config\HomeSeer2.mdb has been closed.
                    12/7/2012 12:00:32 PM - Startup - HomeSeer version is: 2.5.0.49
                    12/7/2012 12:00:32 PM - Startup - Starting remoting (Remote client connection monitor)
                    12/7/2012 12:00:32 PM - Startup - Creating Speaker Client Interface Object...
                    12/7/2012 12:00:32 PM - Startup - Initializing phone interface...
                    12/7/2012 12:00:33 PM - HSPhone - HomeSeer Phone Web Interface initializing.
                    12/7/2012 12:00:33 PM - Startup - Checking for pending updates to be installed...
                    12/7/2012 12:00:33 PM - Startup - Restoring Device Status...
                    12/7/2012 12:00:33 PM - Startup - Checking for available plug-ins
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: AC-RF2 Processor, version: 1.1.3226.27426
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: ActiveBackup Plugin, version: 2.0.0.26
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: X10 CM11A/CM12U, version: 2.2.0.4
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: X10 CM15AUSB, version: 1.0.0.6
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: DSC Security, version: 2.0.0.14
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: HSTouch Server, version: 1.0.0.60
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: HSTouch Android, version: 1.0.0.2
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: HSTouch iPhone, version: 1.0.0.2
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: HSTouch Server Unlimited, version: 1.0.0.1
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: Insteon, version: 1.1.52.1
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: iTunes, version: 2.5.0.13
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: Media Player, version: 2.5.0.16
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: RainRelay8, version: 1.0.0.11
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: RCS Serial Thermostats, version: 2.4.0.7
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: RCS X10 Thermostat, version: 2.0.0.105
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: ACT TI103, version: 2.0.0.5
                    12/7/2012 12:00:33 PM - Plug-In - Found plug-in: UPB, version: 1.0.2.7
                    12/7/2012 12:00:34 PM - Plug-In - Found plug-in: WebCam, version: 2.0.0.2
                    12/7/2012 12:00:34 PM - Startup - Initializing Plug-Ins
                    12/7/2012 12:00:34 PM - Plug-In - Initializing Plug-in: Media Player
                    12/7/2012 12:00:34 PM - Plug-In - Finished initializing plug-in Media Player
                    12/7/2012 12:00:34 PM - Plug-In - Interface AC-RF2 Processor is running as a trial, 23 days remaining.
                    12/7/2012 12:00:34 PM - AC-RF2 Processor - AC-RF2 Processor Plugin Version Release 1.1.3226.27426 Has Registered. Plugin Copyright (c) 2008 - AutomationCraft, LLC.
                    12/7/2012 12:00:34 PM - Plug-In - Initializing Plug-in: AC-RF2 Processor
                    12/7/2012 12:00:34 PM - AC-RF2 Processor - Device #1 Initializing - (W800RF32 receiver on Com 4)
                    12/7/2012 12:00:34 PM - Media Player - MPAppThreadProc start
                    12/7/2012 12:00:34 PM - Media Player - Loading library in the background, this could take a few minutes...
                    12/7/2012 12:00:34 PM - Media Player - Getting track information...
                    12/7/2012 12:00:35 PM - AC-RF2 Processor - The RF receiver was initialized on Com 4 - Ready to start I/O
                    12/7/2012 12:00:36 PM - Plug-In - Finished initializing plug-in AC-RF2 Processor
                    12/7/2012 12:00:36 PM - Plug-In - Initializing Plug-in: RCS X10 Thermostat
                    12/7/2012 12:00:36 PM - COM Plugin - Calling InitIO
                    12/7/2012 12:00:36 PM - RCSX10 Info - RCS X10 Thermostat version is: 2.0.105
                    12/7/2012 12:00:36 PM - startup - Initializing plug-in ...
                    12/7/2012 12:00:36 PM - COM Plugin Info - Initializing RCS X10 Thermostat 2.0.105 ...
                    12/7/2012 12:00:36 PM - RCSX10 Info - Plug-In Debug Mode has been disabled
                    12/7/2012 12:00:36 PM - RCSX10 Info - Plug-In activated
                    12/7/2012 12:00:36 PM - Plug-In - Finished initializing plug-in RCS X10 Thermostat
                    12/7/2012 12:00:36 PM - Plug-In - Interface WebCam is running as a trial, 23 days remaining.
                    12/7/2012 12:00:36 PM - Plug-In - Initializing Plug-in: WebCam
                    12/7/2012 12:00:36 PM - COM Plugin Info - WebCam Plugin (c) 2003 HomeSeer Technologies LLC
                    12/7/2012 12:00:36 PM - COM Plugin Info - Version 2.0.2 Initializing.
                    12/7/2012 12:00:36 PM - WebCam - WebCam Plug-In Version 2.0.2
                    12/7/2012 12:00:36 PM - WebCam - ERROR STARTING: No video devices found or all devices are disabled.
                    12/7/2012 12:00:36 PM - Plug-In - Finished initializing plug-in WebCam
                    12/7/2012 12:00:36 PM - HSTouch Server Unl - Register callback completed
                    12/7/2012 12:00:36 PM - Plug-In - Initializing Plug-in: HSTouch Server Unlimited
                    12/7/2012 12:00:36 PM - HSTouch Server Unl - HSTouch Server Unlimited plugin initialized.
                    12/7/2012 12:00:36 PM - Plug-In - Finished initializing plug-in HSTouch Server Unlimited
                    12/7/2012 12:00:36 PM - Plug-In - Initializing X10 Plug-in: ACT TI103 On COM Port 3
                    12/7/2012 12:00:36 PM - Plug-In - Initializing Plug-in: ACT TI103
                    12/7/2012 12:00:36 PM - Info - TI103 Plug-in, Version 2.0.5
                    12/7/2012 12:00:36 PM - Media Player - Done getting track information
                    12/7/2012 12:00:38 PM - Info - TI103, Communications established at 9600 baud
                    12/7/2012 12:00:38 PM - Plug-In - Finished initializing X10 interface ACT TI103
                    12/7/2012 12:00:38 PM - Plug-In - Finished initializing infrared interface
                    12/7/2012 12:00:38 PM - Web Server - Local IP address (subnet) is: 192.168.1.75 (255.255.255.0)
                    12/7/2012 12:00:38 PM - Web Server - UPNP Discovery started
                    12/7/2012 12:00:38 PM - Web Server - Web Server started on port 80
                    12/7/2012 12:00:38 PM - Startup - Creating ASP.NET application host...
                    12/7/2012 12:00:38 PM - Web Server - SSL Web Server started on port 443
                    12/7/2012 12:00:38 PM - Media Player - Finished loading Playlists
                    12/7/2012 12:00:38 PM - Media Player - Library loading completed.
                    12/7/2012 12:00:58 PM - Media Player - Warning, queued command did not complete due to timeout: player_state
                    12/7/2012 12:00:58 PM - Startup - ASP.NET application host created
                    12/7/2012 12:00:58 PM - Startup - Initializing email 1 0
                    12/7/2012 12:00:58 PM - Startup - Start automation engine...
                    12/7/2012 12:00:58 PM - email - Email receive thread started
                    12/7/2012 12:00:58 PM - Startup - This version of HomeSeer is registered.
                    12/7/2012 12:00:58 PM - Startup - Initializing Speaker Client Interface
                    12/7/2012 12:00:58 PM - Speech - Listening for remote speaker connections on port 8742
                    12/7/2012 12:00:58 PM - Startup - HS2Sentry is disabled in Setup, sentry will not be started.
                    12/7/2012 12:00:58 PM - Startup - Starting Event Scheduler...
                    12/7/2012 12:00:58 PM - Startup - Checking HTTP connection...
                    12/7/2012 12:00:58 PM - Web Server - Web Server authorized local login successful from: 127.0.0.1 User: Bauerlein99
                    12/7/2012 12:00:58 PM - Startup - Updater services starting...
                    12/7/2012 12:00:58 PM - Startup - Starting DDNS service...
                    12/7/2012 12:00:59 PM - Warning - Dynamic DNS update failed with error: nohost
                    12/7/2012 12:00:59 PM - Warning - The update process has been suspended until the configuration in setup is updated with the correct information.
                    12/7/2012 12:00:59 PM - Startup - Running the Startup.txt Script
                    12/7/2012 12:00:59 PM - Startup - Scripting is OK and is now running Startup.txt
                    12/7/2012 12:00:59 PM - Startup - Start up complete.
                    12/7/2012 12:00:59 PM - Web Server - Web Server authorized local login successful from: 192.168.1.75 User: Bauerlein99
                    12/7/2012 12:01:00 PM - Error - Sending email using SMTP: The server rejected the sender address. The server response was: 553 From address not verified - see http://help.yahoo.com/l/us/yahoo/mai...ndfrom-07.html
                    12/7/2012 12:01:02 PM - Error - Unable to connect to POP server pop.mail.yahoo.com Error: Received negative response from POP3 server: -ERR [AUTH] Access to this service is not permitted.
                    12/7/2012 12:01:05 PM - Network - Speaker client connected from: 127.0.0.1
                    12/7/2012 12:01:05 PM - Warning - Speaker client at 127.0.0.1 (BLACKHAWK) was connected because no password is required for the local subnet, but the password, user ID (default), or access rights are NOT valid for a remote network login.
                    12/7/2012 12:01:05 PM - Speaker - Speaker host added, Name: BLACKHAWK IP address: 127.0.0.1
                    12/7/2012 12:01:30 PM - Error - Sending email using SMTP: The server rejected the sender address. The server response was: 553 From address not verified - see http://help.yahoo.com/l/us/yahoo/mai...ndfrom-07.html
                    12/7/2012 12:02:00 PM - Error - Sending email using SMTP: The server rejected the sender address. The server response was: 553 From address not verified - see http://help.yahoo.com/l/us/yahoo/mai...ndfrom-07.html
                    12/7/2012 12:02:31 PM - Error - Sending email using SMTP: The server rejected the sender address. The server response was: 553 From address not verified - see http://help.yahoo.com/l/us/yahoo/mai...ndfrom-07.html
                    12/7/2012 12:02:31 PM - Warning - Sending email To: bauerlein44@yahoo.com aborted after 4 tries
                    12/7/2012 12:06:01 PM - Event - Event Trigger "Jon00s Check Email"
                    12/7/2012 12:06:01 PM - Event - Running script in background: CheckEmailPOP_V3_HS2.vben("main","normal")
                    12/7/2012 12:06:01 PM - Jon00_Email - Checking Mailbox one for E-Mail (mailbox 1)
                    12/7/2012 12:06:01 PM - Jon00_Email - Error in Pops subroutine Block B: 339 - Component 'mswinsck.ocx' or one of its dependencies not correctly registered: a file is missing or invalid
                    12/7/2012 12:06:01 PM - Jon00_Email - There are no changes at the mail server for Mailbox one
                    12/7/2012 12:06:01 PM - Jon00_Email - Error in Pops subroutine Block T: 339 - Component 'mswinsck.ocx' or one of its dependencies not correctly registered: a file is missing or invalid
                    12/7/2012 12:06:01 PM - Jon00_Email - Mailbox one has 0 new emails
                    12/7/2012 12:06:01 PM - Jon00_Email - Mailbox one has 0 emails in this mailbox
                    12/7/2012 12:10:40 PM - X10 Received - D5 (1st Floor Garage Workbench Outlet) D Hail Ack
                    12/7/2012 12:10:59 PM - X10 Received - D5 (1st Floor Garage Workbench Outlet) D Hail Ack
                    12/7/2012 12:11:05 PM - Error - Unable to connect to POP server pop.mail.yahoo.com Error: Received negative response from POP3 server: -ERR [AUTH] Access to this service is not permitted.
                    12/7/2012 12:12:00 PM - Device Control - Command sent to 1st Floor Garage Workbench Outlet: D5 Off Dimval: 0 Data: 0
                    12/7/2012 12:12:00 PM - X10 Received - D5 (1st Floor Garage Workbench Outlet) D Off
                    Next step now is to play with antenna location I guess. The RF connection between the front porch motion sensor and the antenna is the variable I should look at, right? The troubleshooting I've done leads me to believe that. Well, here goes. Thanks again.
                      Okay guys. I moved the antenna maybe 2 feet and lowered it and now all my motion sensors are sending RF signals that are being converted to powerline commands and my RF Devices are operating normally now.
                      Like I've said, I am new to this so I am surprised that the antenna location was so critical. I thought by going to the W800USB WGL RF Antenna Kit, I was improving the whole RF function in my system. So I learned.
                      Again, can't thank you guys enough for the help. Hopefully I will be in a position someday to provide assistance to some newbie who is struggling.
                      If you have read my log posts, it is apparent that I have other issues to deal with. I will pick one issue and ask for help in the proper discussion area. Unless anyone has any ideas on what would be the next most important step? Thanks
                        Yeah; thought you were using a CM11A; works the same though with a TI103. Funny here I have had and used just about every X10 interface that HS every sold.
                        The WGL W800 antenna I used is on the main floor of the house is the same one you purchased. It is buried in a wall behind one of the in wall speakers in the middle of the house.
                        I purchased a Radio Shack scanner antenna for the second W800. This is mounted in my attic above the second floor of my house.
                        There are a few HS users which also use the same Radio Shack scanner antenna. I purchased it on sale a few years ago. Do a quick search and you will find how folks are connecting the W800 to an antenna. You will also see some home brew antenna stuff from the MR26A days.
                        I can go about three houses away from my house to trigger W800 configured variables with this setup.
                          You should be able to get better reception with the w800. It's a good device. As suggested, you might benefit from the antenna additions. It looks like a spider. If you go this route and still have problems, attach a UHF booster at the antenna end.
                            Attached is a picture of the antenna I have in the attic.
                            I thought it had been discontinued by Radio Shack and noticed that they still sell it.
                              Thank you very much guys. I would very much like to make my RF circuit as strong as possible. Never know what the future will bring. So I will check out Radio Shack. Looking at the picture, that antenna has got to go in the attic. With all the stuff going on with me learning this new software and hardware, the WAF is a little touchy right now. What's the best move? The antenna or the UHF Booster?
