I restarted the service and tested the tiles don't update on their own but if I refresh the browser it updates
Windows Style Live-Tile UI for HomeSeer
Originally posted by kideon View PostI restarted the service and tested the tiles don't update on their own but if I refresh the browser it updates
I verified the port 6152, when I run it manually I get this:
C:\Program Files\HomeSeer HS3\html\HSMetro>node proxy.js 192.168.2.103
Proxy server running and broadcasting on port 6512
events.js:85
throw er; // Unhandled 'error' event
Error: listen EADDRINUSE
at exports._errnoException (util.js:746:11)
at Server._listen2 (net.js:1156:14)
at listen (net.js:1182:10)
at Server.listen (net.js:1267:5)
at Object.<anonymous> (C:\Program Files\HomeSeer HS3\html\HSMetro\proxy.js:8
3:16)
at Module._compile (module.js:460:26)
at Object.Module._extensions..js (module.js:478:10)
at Module.load (module.js:355:32)
at Function.Module._load (module.js:310:12)
at Function.Module.runMain (module.js:501:10)
Originally posted by kideon View Postok I did the above and the proxy is running, I can see messages being passed but still no dice on the tile update
Which tiles do you have configured? Did you refresh your UI when you restarted the proxy?
Originally posted by wposner View PostIcons come from HS. That has always been my end goal for icons on the tiles. If the functionality was there initially I never would have introduced the icon parameter.
You can create a double height and width tile by using class="tile-large".
The tile color now indicates mode (off, cool, heat, auto change-over, emergency heat) as opposed to using an icon. You can edit the JS if you don't like the predefined colors.
For the thermostat, not sure what's going on there.
Code:if (self.modeValue() == OFF) { self.defaultColor=OFF_COLOR; self.classInfo(_classInfo + OFF_COLOR);
Code:var OFF_COLOR="bg-gray";
For the large tile can you post over in the feature request thread and give a detailed description of what you're looking for. What kind of device are you trying to control? What info are you looking to display on the tile? Reasons for tile size. That'll help trying to gauge the request
As for the tstat can you post a screen shot? The color param no longer works for tstat tiles since colors are used to now define mode. What kind of tstat are you using? What are it's valid operating modes? I may have messed something up so I need to make sure your device isn't unique in the modes it reports to HS.
Originally posted by kideon View PostI refreshed the UI, using text status (which refreshes fine), regular status the clock, device, and weather. Where do I find the console and Chrome dev tools?
The console will be at the bottom right. You're not using any thermostat widgets? And the <hstextstatusdevice> widget is getting live updates while other widgets are not?
I am experiencing a similar behavior with tiles not updated. The clock and weather seem to be updating automatically. I haven't done much research/trouble shooting into it but every morning I need to refresh the tiles and anytime I leave the tablet for any length of time. If I refresh, then turn on switches, it updates automatically. It is only when left alone for a while.
I did read some where that Chrome had a bug not keeping a connection and they had to use Firefox as a work around but it was from 2011 or so, so it may be worked out by now but I have not tried firefox to see if it helps.
Originally posted by olag00 View PostI am experiencing a similar behavior with tiles not updated. The clock and weather seem to be updating automatically. I haven't done much research/trouble shooting into it but every morning I need to refresh the tiles and anytime I leave the tablet for any length of time. If I refresh, then turn on switches, it updates automatically. It is only when left alone for a while.
Can you tell me how many tiles you have, and the count of each type? Also, how many instances of the UI are you running?
