WeatherXML 3.0.0.79
    WeatherXML 3.0.0.79
    Hello Jeff,
    Installed WeatherXML new on 2nd Homeseer 3 machine and noticed the following.
    I do not know why I am seeing this as it is the same configuration on the HS3 Pro machine. Did a side by side configuration.
    Thinking I missed something in the configuration. It is only related to the forecast download. If I disable the event to download the forecast the error goes away.
    Dec-09 5:01:02 AM weatherXML Error setForecastDataArray: Method 'System.String[].Set' not found.
    Dec-09 6:01:01 AM weatherXML Error setForecastDataArray: Method 'System.String[].Set' not found.
    Dec-09 7:01:02 AM weatherXML Error setForecastDataArray: Method 'System.String[].Set' not found.
    <table class="log_table_row" cellspacing="0"><tbody><tr> <td class="LogDateLong LogDateTime1" colspan="1" style=" white-space: nowrap;" align="left">
    </td><td class="LogPri1" colspan="1" align="left">
    </td><td class="LogType1" colspan="3" align="left">
    </td><td class="LogEntry1" colspan="8" align="left">
    </td></tr></tbody></table>
    I switched the forecast over from NOAA to WeatherUnderground and the error above went away.
    It is odd that I am using the NOAA forecast on machine #1 and it works fine.
      Did you check the xml files to see if any data was being downloaded?
      Jeff Farmer
      HS 3, HSPhone
