I have been running the W800 1.7 version which worked except that I would get an error when trying to get to the config and config would never open.
I diabled the W800, restarted HS2, then updated with the AC RF Processor. I enabled the AC RF, restated HS2, then tried to use the config and again get an error.
8/15/2005 6:02:10 PM AC RF Processor AC RF Processor Plugin Version Release 1.0.4 Has Registered. Plugin Copyright (c) 2005 - AutomationCraft, LLC.
8/15/2005 6:02:10 PM AC RF Processor Using INI file for options storage - File: C:\Program Files\HomeSeer 2\Config\ACRFProcessor.INI
8/15/2005 6:02:10 PM COM Plugin Calling InitIO
8/15/2005 6:02:10 PM COM Plugin Info AC RF Processor RF->Serial I/F Copyright (c) 2005 - AutomationCraft, LLC.
8/15/2005 6:02:10 PM AC RF Processor Attempting to add one type 0 receiver on Com 5 to RFComm support interface.
8/15/2005 6:02:10 PM AC RF Processor RF Device could not be located on Com 5
8/15/2005 6:02:10 PM AC RF Processor ***:The Com port is not yet setup for the RF device or no devices are responding. Please select 'setup' from HomeSeer's Options dialog /Interfaces tab and select the com port and correct device.
8/15/2005 6:02:11 PM DooNetwork Info Network AB VM computer is connected
8/15/2005 6:02:11 PM Info Done initializing plug-in AC RF Processor
8/15/2005 6:03:06 PM ConfigIO Calling ConfigIO for AC RF Processor
8/15/2005 6:03:07 PM AC RF Processor ***:ConfigIO - Unable to display configuration dialog
SteveD
SteveD
