I am using your application with one of three of the RFID units. Its been working fine up until a couple of days ago. (years now)
Just noticed that it doesn't appear to see any tags. I just shut down HS to validate that there is data on the com port and there is.
This happened once before (maybe last year). I just re-installed the plugin and all came back just fine.
This morning I initially disabled the plugin and re-enabled it; nothing.
I then shut down HS and installed it fresh; still nothing.
I just enabled debug and logging and see nothing.
Funny thing is I have not touched nor modified anything directly with the plugin nor modified any of the events that are being utilized with the plugin.
Any suggestions relating to my next steps?
Or should I just remove the plugin and not bother utilizing it anymore?
Nothing in the logs other than the above indicating that the plugin is working. Historically I would see the tags in either the BLRFID logs or the HS logs (both on right now).
Here is a snippet of the detailed log. It also doesn't appear to be seeing the tags; yet I can see them fine via a direct serial connection.
Should I post the debug logs (they are about 9 megs each from this morning)?
6/14/2011 10:16:10 AM Plug-In Shutting down generic Plug-In: BLRfid
6/14/2011 10:16:10 AM BLRfid end BLRfid is shutting down...
6/14/2011 10:16:10 AM BLRfid end RFID receiver #1 (COM15) is Closed!
6/14/2011 10:16:11 AM BLRfid end BLRfid plugin has been shutdown
6/14/2011 10:16:21 AM BLPlugins start Register Callback completed
6/14/2011 10:16:21 AM BLPlugins start BLPlugins version is: 1.0.13.0
6/14/2011 10:16:21 AM Plug-In Initializing Plug-in: BLPlugins
6/14/2011 10:16:21 AM BLPlugins start Initializing BLPlugins...
6/14/2011 10:16:21 AM BLPlugins start Loaded configuration successfully
6/14/2011 10:16:22 AM BLPlugins start BLPlugins plugin has been initialized
6/14/2011 10:16:22 AM Plug-In Finished initializing plug-in BLPlugins
6/14/2011 10:16:36 AM Plug-In Shutting down generic Plug-In: BLPlugins
6/14/2011 10:16:36 AM BLPlugins end BLPlugins is shutting down...
6/14/2011 10:16:37 AM BLPlugins end BLPlugins plugin has been shutdown
6/14/2011 10:16:46 AM BLRfid start Register Callback completed
6/14/2011 10:16:46 AM BLRfid start BLRfid version is: 1.0.38.0
6/14/2011 10:16:46 AM Plug-In Initializing Plug-in: BLRfid
6/14/2011 10:16:46 AM BLRfid start Initializing BLRfid...
6/14/2011 10:16:46 AM BLRfid start Loaded configuration successfully
6/14/2011 10:16:46 AM BLRfid start BLRfid Debug Logging is Enabled!
6/14/2011 10:16:46 AM BLRfid start RFID Tags and Groups have been loaded.
6/14/2011 10:16:46 AM BLRfid start RFID Receiver #1 (COM15) is Open!
6/14/2011 10:16:46 AM BLRfid start BLRfid plugin has been initialized
6/14/2011 10:16:46 AM Plug-In Finished initializing plug-in BLRfid
