Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Blade Plug-Ins > BLML2HS (3P)
BLML2HS (3P) Discussion of Blade's BLM2HS Plug-in
Old December 10th, 2015, 08:53 PM
sonypoolplr sonypoolplr is offline
Trying to Send Command to HS3
Helo,
I just started using this with HS3 and I don't know all the syntax needed to send commands to HS. I am trying this:
ML2HS|HS-SetDeviceValue~E1~100
But the device in HS isn't changing. Is there a command list somewhere? I tried the command builder in MLServer, but that was confusing.
Thank you.
Old December 11th, 2015, 08:27 AM
I also tried:
BLML2HS|HS-ControlDevice~003D0C47-006-Q58~On and
BLML2HS|HS-ControlDevice~E1~On
And I see the commad in the plugin, but nothing happens in HS. I attached the debug file, at leat the one I think it is.
Old December 11th, 2015, 10:03 AM
Blade's Avatar
Blade Blade is online now
Try 2.0.18 in the HS3 updater
Cheers,
Bob
Send HTTP or IP command FernandoSolanes HomeSeer General Discussion Area 7 January 20th, 2012 08:19 PM
Send an IR Command Tom Kern HSTouch™ 13 May 2nd, 2010 05:53 PM
Help with RS-232 Send Command djmuzz Programming with HomeSeer 4 November 29th, 2006 04:36 AM
Can an Event Send a Command Line Command? independentpete HomeSeer General Discussion Area 2 May 18th, 2004 09:06 PM
