The instructions say to install "HomeSeer Home Automation Skill". I have done that but it doesn't see any of my devices. I then installed the skill "HomeSeer". Now Alexa can see some devices. However, this seems an older version, or is it? Which one should really be installed?
Which Skill
There are two skills..., one which uses an API, and one which is more generic.
The API one is the 'HomeSeer' skill, located in the 'Smart Home' group of the Alexa app.
The generic one is the 'HomeSeer Home Automation' skill.
Each skill has pros and cons for HS3 users.
The skills can be enabled and used by themselves, or both can be enabled simultaneously.
The API skill does a discovery of devices in your HS3 system, while the generic one looks for the device after the command is processed.
The API allows on/off/dim/set commands for devices if they have the status pair control use set properly.
The generic skill allows for any command word available on the device.
Both skills require the device to be controlled to have the 'voice command' option enabled (in the configuration area of the device)
The API uses the context of 'Alexa, [command]', whereas the generic skill uses 'Alexa, tell HomeSeer to [command]'.
The generic skill allows for control of events by name or phrase, and can set timed commands.Wade
"I know nothing... nothing!"
Originally posted by Sgt. Shultz View PostThere are two skills..., one which uses an API, and one which is more generic.
Or is it a case that it is not available in the UK?sigpic
Originally posted by Gogs View PostIn ALexa SKills I only have HomeSeer Home Automation Skill and HomeSeer. HomeSeer is the BEta one I have always ben connected with!
Neither skill is a beta..., one is an API based skill and one is not.
The one that is titled 'HomeSeer Home Automation Skill' is not API based.
The one titled 'HomeSeer' is API based.Wade
Originally posted by Sgt. Shultz View PostNeither skill is a beta..., one is an API based skill and one is not.
The one titled 'HomeSeer' is API based.sigpic
Here is a sample that I put together of Alexa voice commands using:
https://1drv.ms/w/s!Atgv-e6whj8phqpJUPiZ1rXr7Ru9Ow
It uses the:
API Skill of Alexa to HomeSeer: http://homeseer.com/amazon-echo-integration.html (Option #1)
IFTTT Alexa to HomeSeer IFFTT Recipe:
http://forum.kodi.tv/showthread.php?tid=254502
A "TV" skill for Kodi:
https://ifttt.com/recipes/470602-ale...homeseer-event
