I posted this in another thread
I'm trying to use 2 pgms on me DSC 1832 to run different events so when I set the alarm is stay mode at the keypad it will turn some of the lights to 20%. Away mode all the lights off. Any suggestions would be greatly appreciated
So Far I set section 009 to 18 for stay mode pgm1
then 17 for away mode pgm2 this will give me 13.5 volts for 5 seconds (the time can be adjusted in section 170) on the desired pgm
a relay to turn these into a dry contacts is easily done
I only need a recommended analog input that will run an event
