I migrated my Win7 box to a new Win10 box, however i have an issue with my USB UIRT plugin since.
I installed USBUIRT with the win7 64bit driver from http://www.usbuirt.com/support.htm
Driver states its functioning fine. however when I start the plugin it, states;
i triedconnecting and disconnecting and other drivers with no succes. Any ideas howto solve this issue?
Bart
nov-27 11:53:44 Error Initializing plug-in(1): BLUSBUIRT Instance::Unable to communicate with USB-UIRT device! Please check connections and try again. If you still have problems, try unplugging and reconnecting your USB-UIRT. If problem persists, contact Technical Support
Bart
