error message; how to address?
    Just installed plug-in with Proliphix NT160. Always get this error message when I try to change temperature; how to address this?
    Nov-28 4:50:42 PM Error Calling SetIOMulti in plugin IPThermostat:Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index
    Can you sent me some more logging with debug on pleasse
    Rien du Pre
    The Netherlands
    Using:
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      Thank you for your help...
      here is the detailed log surrounding requests to increase, decrease and set the setpoint to 60deg
      Dec-02 5:39:09 PM IPThermostat DEBUG1: GetLogLevel: Entered function
      Dec-02 5:38:48 PM IPThermostat DEBUG1: PollProliphix Thermostat: Increased failed poll counter for '192.168.1.124' to 2
      Dec-02 5:38:48 PM IPThermostat ERROR: PollProliphix: Cannot query http://192.168.1.124:8082/get?OID4.1.4=:http://192.168.1.124:8082/get?OID4.1.5=:
        What output do you get when you execute http://192.168.1.124:8082/get?OID4.1.4= in a browser from your HS server ?
        Rien du Pre
        The Netherlands
        Using:
        Plugin's:
          The first thing I get is the login screen to my Proliphix tsat
          After I login I get:
          OID4.1.4=1&
            This response is correct
            It seems like the thermostat is 'choking', due to the number of request in a short time.
            I remember I had this too, during plugin development, when I had to send many request during testing.
            A reset of the thermostat solved this. Can you try this too?
            Otherwise I have to add a pause after each command, which will slow down plugin performance.
            Rien du Pre
            The Netherlands
            Using:
            Plugin's:
              I'm sorry, but that didn't change anything...
                Follow-up
                So what is the plan?
                  Solved
                  Thank you to the developer. This problem was corrected by a tweaked version of the plug-in...
