Blade Message Board Down?
    Tried to find an answer to the question below on the original message board but it seems to be down?
    When using BLReminders with the Frequency set to 'Every X Days' should I use a count down timer as well as 'speak on day'? Have not been able to setup a combination that works when using the frequency option.
    I'm pretty sure it was only the countdown and the days before that you couldn't use together. You don't need both of those if you don't want. The more important one is the speak on day square checked, even if you're not speaking but rather going to run a script or event.
    Marty
