I've been looking into these power monitors the last few days. I was originally thinking about the TED because of the gateway device and not requiring a PC. But there are a lot of negative reviews for it on Amazon. I don't really use X10 so that is not an issue for me, but it appears to have low quality.
That brings me to the Current Cost. This device is a little more confusing to me how it hooks up to HS. It looks like you have to wire the display to HS all the time which is bad for me because my HS PC is in the garage media cabinet. I'd like to be able to see the display in the house. It also looks like you need to buy this Webbridge device to make the readings available online.
How does the current cost work with the web bridge and HS at the same time? Can you locate the Display away from the HS PC?
