BLLED is in development
    I know that is not the debug log. I was trying to show that the plugin didn't pick up anything from the ini file. I should have been more specific.
    I didn't change any text label/size because the plugin says there are no LED signs configured.
    I'll recreate the sign and try again.
      Before you do that.
      Do this:
      1. shutdown HS3
      2. Edit the hspi_BLLED.ini and change debugLevel=true
      3. Save ini
      4. Restart HS3
      Once started then turn off debug logging and attach debug zipped
      Cheers,
      Bob
        I changed the size on label C from 100 to 128
          It is updated in the INI, correct?
          But the edit page still shows 100?
          Cheers,
          Bob
            I shutdown HS3, changed debugLevel to true saved and restarted HS3. Then opend the BLLED Sign webpage. And finally shutdown HS3.
              Please attach your hspi_BLLED.ini zipped
              Cheers,
              Bob
                Nevermind, I think I found it
                Cheers,
                Bob
                  Try 1.0.24 in the updater
                  Cheers,
                  Bob
                    Blade,
                    The problem blank out the field is fixed.
                    Thank you
                    Greg
                      Have .24 installed and running and everything looks good.
                      Thank you Bob.
                        No problem. Enjoy
                        Cheers,
                        Bob
                          Blade, I ran in to one slight issue with the remote plugin. The remote instance is restarted or If HS3 is restarted the plugin looses its setting for the remote instance there are no signs so everytime you restart the plugin you have to re-enter all of the sign config info can you look into this
                          Cheers Ken
                          HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
                            They should be stored in the folder on the remote machine.
                            Is there a hspi_BLLED.ini file in the config folder
                            Cheers,
                            Bob
                              The config folder is there but its empty
                              Sent from my EVO using Tapatalk
                                It looks to me like it is trying to send the info to the INI file for the main instance
