I got the API authentication. The only thing that shows up under my users is calendar. I click on it and then try to add a calendar and it won't let me add anything. What am I missing?
Can't get it to work
I need a debug log in order to see what the issue is
Log a help desk ticket on my site.
gather a debug log using steps below
1. Shutdown HS3
2. Edit hspi_BLGData.ini and change debugLevel=true
3. Save INI file
4. Restart HS3
Once started for a minute or so, turn off debug logging and attach the BLGData-Detailed.log file zipped to help desk ticket
The log is in the HS3 root folder
A few minutes after I click on my 'calendar' in HS3.
Error finding plugin in GenPage: Object reference not set to an instance of an object.
Here are the pertinent parts of the debug log.
8/12/2016 1:00:24 PM : v2.0.24.0 - CalendarFunctions.Create_Google_Auth_File() started
8/12/2016 1:00:24 PM : v2.0.24.0 - CalendarFunctions.Create_Google_Auth_File(): aUser.ToString -->
User:
Key: ******************
EmailAddress: *******************
EnableCalendar: True
EnableContacts: False
EnableTasks: False
EnableVoice: False
EnableGooglePlus: False
Calendar Count: 0
Contact Count: 0
Contact Group Count: 0
ProcessedEvents: 0
ProcessedEventOffsets: 0
ProcessedReminders: 0
8/12/2016 1:00:24 PM : v2.0.24.0 - Linux() started
8/12/2016 1:00:24 PM : v2.0.24.0 - Linux(): isLinux --> False
8/12/2016 1:00:24 PM : v2.0.24.0 - Linux() finished
8/12/2016 1:00:24 PM : v2.0.24.0 - CalendarFunctions.Create_Google_Auth_File(): fileName --> C:\Program Files (x86)\HomeSeer HS3\Data\BLGData\client_secrets.json
8/12/2016 1:00:24 PM : v2.0.24.0 - CalendarFunctions.Create_Google_Auth_File() finished
