No problems controlling the Russound with the plugin now - but when I go to a keypad and change the source or change the volume, the associated device in HS doesn't change value. But, power does work perfect which is strange. If I press power on the keypad the status in HS updates instantly...
I enclosed a log where on Unit 1, Zone 6 I went to the keypad, changed the volume and the source - both actions did not change the associated device in HS.
