CAM6.6 Mute
    CAM6.6 Mute
    Hi Blade,
    I ran into a new problem today. When the source (for me) is #1 which is my ST2 (XM Radio) and you push the pause button on the keypad, it puts the speakers for that room on Mute. This is not reflected anywhere in the plug in and no way to take it off mute except by the keypad.
    Can we get a child device of Mute with an on and off button?
    Do you need a debug log capturing the keypad going on mute and then coming off mute?
    Michael
    HS3Pro & HS4Pro on Win2012R2
    Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
    BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-Wave
    Hmmm I was not aware there was a mute command
    A debug log would be good
    Cheers,
    Bob
      I turned on debug
      Stopped the plugin
      Started the plugin
      waited until I saw: BLRussound Info Russound Com Port - HomeSeer (COM2) Open
      Went to my living room keypad (zone 4)
      Pressed the on/off button
      Waited until the music came on and I could hear it in the speakers
      Press the Pause button (mute)
      Waited about 15 seconds
      Press the Pause button (unmute)
      Pressed the on/off button to turn off
      Went back and set the debug off
      Turned the plug in off
      Turned the plug in On
      Not sure I caught everything as the log seems small. I also used the PowerTool and below is a screen capture of the pause key.
      EDIT: I did it again with the output to HS log turned on. Attached it. I see the message where the Pause button was pushed.
      Michael
        Bump. Any progress on this yet?
          Not yet - I need to spend some time on this
          It must be coming from the ST2 tuner - I have an ST2 tuner and almost have it hooked up so I will test it out once I get it going
          Cheers,
          Bob
