[UPDATED 11/8/13]
HS3 for Linux has been posted in the HS3 Beta forum.
Each update in the updater contains information about which version of HS3 your plugin supports. Since plugins have not been tested on Linux yet, you should set your updater line so the plugin will not load on Linux. Once you verify your plugin supports Linux you can enable it for that OS.
The updater line looks like this (only the first section):
Z-Wave, HSPI_ZWave.exe, ,3.0.0.13, 31
Note the "31", this indicates that the plugin works on Windows only. So this update will not appear under Linux. Ensure that your updater line is set to 31. This is important for authors who are hosting their own updates as we cannot change this. If we are hosting the update, we will automatically set the update to 31 until you submit an update that is Linux compatible.
If your plugin works for both Windows and Linux, the # is 63, for Linux only, its 47.
