Restart Plugin for HS3
    The Restart Plugin allows you to restart HomeSeer, reboot the HomeSeer server or shut down the HomeSeer server.
    Web interface has a button for each of the 3 actions.
    Restart HomeSeer, Restart HomeSeer server and Shut Down HomeSeer server are available as Event actions.
    You can add an icon to your Startup Folder that will allow you to set how many seconds before HomeSeer should be started. This allows windows to completely start before starting HomeSeer.
    Restart is available in the Plugin Manager in the Utilities category.
    Jeff Farmer
    HS 3, HSPhone
    Version 1.0.0.2 is in the updater.
    1.0.0.2
    Fixed an issue where the page tabs weren't lined up correctly. You have to use the HS menu at the top of the page to move between the User page and the Admin pages.
    Jeff Farmer
    HS 3, HSPhone
      Version 1.0.0.3 is in the updater.
      1.0.0.3
      Added an option to Shutdown HS
      Jeff Farmer
      HS 3, HSPhone
        1.0.0.4
        The server reboot/shutdown now waits for HS3 to close before the server reboot/shutdown begins.
        Jeff Farmer
        HS 3, HSPhone
          1.0.0.5
          Moved the settings to be on the Restart tab of the Restart Version device.
          Jeff Farmer
          HS 3, HSPhone
