Any possibility of adding S_SMOKE?
In any event, thanks for all your hard work!!
5/23/2015 10:35:27 AM | PLUGIN | STATUS | Plugin shutting down 5/23/2015 10:35:27 AM | PLUGIN | STATUS | HSPI_MySensors terminated. 5/23/2015 10:35:37 AM | PLUGIN | GENERIC | HSPI_MySensors running. 5/23/2015 10:35:37 AM | PLUGIN | GENERIC | Assembly: HSPI_MySensors, Version 1.0.5574.17274 5/23/2015 10:35:37 AM | HOMESEER | STATUS | Plugin: MySensors Instance: starting... 5/23/2015 10:35:37 AM | HOMESEER | STATUS | Connecting to server at 127.0.0.1... 5/23/2015 10:35:37 AM | HOMESEER | STATUS | Connection attempt #1 5/23/2015 10:35:38 AM | HOMESEER | STATUS | Connected (HomeSeer API 3). Waiting to be initialized... 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_CONTROLLER (0, 0) registered by the controller. 5/23/2015 10:35:38 AM | MYSENSORS | STATUS | MySensors.Controller (0, 0)- Node id allocated: 0 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_TEMP (4, 0) registered by the controller. 5/23/2015 10:35:38 AM | MYSENSORS | STATUS | MySensors.Controller (0, 0)- Node id allocated: 4 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_TEMP (4, 0) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_TEMP (4, 0) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_ARDUINO_NODE (7, 255) registered by the controller. 5/23/2015 10:35:38 AM | MYSENSORS | STATUS | MySensors.Controller (0, 0)- Node id allocated: 7 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_ARDUINO_NODE (7, 255) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.S_DEVICE (7, 255) - Configuration initialized by user to Imperial. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_ARDUINO_NODE (7, 255) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_TEMP (7, 0) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_TEMP (7, 0) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_TEMP (7, 0) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_ARDUINO_NODE (5, 255) registered by the controller. 5/23/2015 10:35:38 AM | MYSENSORS | STATUS | MySensors.Controller (0, 0)- Node id allocated: 5 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_ARDUINO_NODE (5, 255) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.S_DEVICE (5, 255) - Configuration initialized by user to Metric. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_ARDUINO_NODE (5, 255) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_TEMP (5, 0) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_TEMP (5, 0) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_TEMP (5, 0) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_LIGHT (7, 1) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_LIGHT (7, 1) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_LIGHT (7, 1) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_LIGHT (7, 2) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_LIGHT (7, 2) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_LIGHT (7, 2) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_LIGHT (7, 3) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_LIGHT (7, 3) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_LIGHT (7, 3) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_ARDUINO_RELAY (9, 255) registered by the controller. 5/23/2015 10:35:38 AM | MYSENSORS | STATUS | MySensors.Controller (0, 0)- Node id allocated: 9 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_ARDUINO_RELAY (9, 255) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.S_DEVICE (9, 255) - Configuration initialized by user to Imperial. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_ARDUINO_RELAY (9, 255) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_LIGHT (9, 1) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_LIGHT (9, 1) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_LIGHT (9, 1) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_CONTROLLER (0, 0) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_ARDUINO_NODE (1, 255) registered by the controller. 5/23/2015 10:35:38 AM | MYSENSORS | STATUS | MySensors.Controller (0, 0)- Node id allocated: 1 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_ARDUINO_NODE (1, 255) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.S_DEVICE (1, 255) - Configuration initialized by user to Imperial. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_ARDUINO_NODE (1, 255) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_ARDUINO_NODE (2, 255) registered by the controller. 5/23/2015 10:35:38 AM | MYSENSORS | STATUS | MySensors.Controller (0, 0)- Node id allocated: 2 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_ARDUINO_NODE (2, 255) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.S_DEVICE (2, 255) - Configuration initialized by user to Imperial. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_ARDUINO_NODE (2, 255) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_HUM (2, 0) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_HUM (2, 0) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_HUM (2, 0) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_TEMP (2, 1) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_TEMP (2, 1) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_TEMP (2, 1) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_TEMP (1, 0) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_TEMP (1, 0) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_TEMP (1, 0) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_LIGHT (1, 1) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_LIGHT (1, 1) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_LIGHT (1, 1) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_LIGHT (1, 2) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_LIGHT (1, 2) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer device status changed in S_LIGHT MySensors object. 5/23/2015 10:35:38 AM | PLUGIN | STATUS | MySensors.S_LIGHT (1, 2) device created (Request from HomeSeer) 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | HomeSeer.Controller - HomeSeer.S_ARDUINO_NODE (4, 255) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.Controller (0,0) - MySensors.S_ARDUINO_NODE (4, 255) registered by the controller. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.S_DEVICE (4, 255) - Configuration initialized by user to Imperial. 5/23/2015 10:35:38 AM | PLUGIN | DEBUG | MySensors.S_DEVICE (4, 0) - Configuration initialized by other MySensors device to Imperial. 5/23/2015 10:35:39 AM | PLUGIN | STATUS | MySensors.S_ARDUINO_NODE (4, 255) device created (Request from HomeSeer) 5/23/2015 10:35:39 AM | HOMESEER | STATUS | Done initializing 5/23/2015 10:35:40 AM | MYSENSORS | DEBUG | MySensors.Gateway - Message received: 0;0;3;0;14;Gateway startup complete. 5/23/2015 10:35:40 AM | PLUGIN | STATUS | MySensors.S_CONTROLLER (0, 0) - Gateway ready. 5/23/2015 10:35:40 AM | MYSENSORS | DEBUG | MySensors.SerialGateway - Message sent: 0;0;3;0;5;0 5/23/2015 10:35:40 AM | MYSENSORS | DEBUG | MySensors.Gateway - Message received: 0;0;3;0;5;0 5/23/2015 10:35:40 AM | PLUGIN | STATUS | MySensors.S_Controller (0, 0) - Inclusion mode: OFF 5/23/2015 10:35:40 AM | PLUGIN | STATUS | HomeSeer.S_CONTROLLER (0, 0) - Inclusion mode: OFF
