Originally posted by spud
View Post
Easy Trigger plug-in - Beta Testing
FYI, the EasyTrigger plugin is now in the store and updater:
http://store.homeseer.com/store/Spud...HS3-P1999.aspx
Originally posted by spud View Postin version 3.0.0.4 (attached to first post of this thread) I have added an action to set a device value to any replacement variable: this can be a global variable, another device value, a counter, basically anything that is in this list and has a numerical value
set device value to a global variable:
[ATTACH]45420[/ATTACH]
set device value to another device value:
[ATTACH]45421[/ATTACH]HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostSince global variables are created on the fly, 1) Does naming a variable in the plug-in create it if it doesn't exist, 2) If so does it require scripting to manipulate the values in the global variable.
2) I don't understand the question
Purchased.
I would also like a nice way to control/set a schedule in HSTouch. This way, it is easy for the wife or I to make adjustments to things that we change around often from our in wall touch screens. Could you brainstorm how to add this? It could be a handful of virtual devices, aggregated to make the schedule. I do this now, but it takes extra scripting and such.
Originally posted by kideon View PostHow about a trigger for if a device has changed in a specified amount of time, if it was one value and became another value and if it has been a value in a certain amount of time.
In the current plugin there is already a trigger for "This device's value was and becomes"
Originally posted by kriz83 View PostI have a humidity sensor (Oregon) and a virtual device with a 'maximum humidity'. If the humidity reaches the max humidity, a dehumidifier is turned on.
I seem to be unable to get this to work. Let me know what to provide in order for you to ease debugging.
Originally posted by Automated View PostHuh. My purchase of the plugin didn't come with a license code. That's never happened before. I will submit a help desk ticket.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostI hadn't noticed,but neither did mine, but the plug-in also doesn't show as a trial with an expiration date either.
I have asked HST guys to look at the license code problem.
Originally posted by spud View Post1) no it assumes the global variable exist at the time the action is triggered. If it doesn't it will probably gives an error (I haven't tested)
As an alternative the replacement variable action works great for that as I have synchronized 3 dimmers for my yard lights. I created an event to set the value of the other two dimmers to the value of the "master" any time it changes.
The "Never" Wait was during testing because I thought the ramp rate might affect the synchronization. It doesn't.
.Last edited by randy; April 13, 2015, 08:26 PM.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by spud View Posthmm, what does it say in the License column of the "PLUG-INS > Manage" page?
I have asked HST guys to look at the license code problem.Last edited by randy; April 13, 2015, 03:24 PM.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
I even tried the support option to have all my license codes emailed to me. The email did not contain the license for Easy Trigger, so the store purchase/licensing feature is somehow broken for sure.
