looks like fun.. one on order !
Fibaro FGMS-001 Z-Wave Motion Sensor
Be interesting to see if the bugs on the battery devices get resolved, mine have been at 100% ever since they were installed which is probably over a month now, I doubt they are at that level considering I am reporting temperature at five minute intervals.
There also a lot of parameters, far more than any of my other devices. It is a painful experience doing it all by hand - perhaps some drop downs can be put in the plugin to help alter all of them?
These right? http://store.homeseer.com/store/Fiba...sor-P2032.aspx
the vibration sensor is pretty cool. You can mount one on your clothes dryer (for instance) and have HomeSeer notify you went the dryer stops... or starts.
Originally posted by jon00 View PostAh it has a vibration sensor!
When I got your email, I thought it had something to do with a blue pill!
Sent from my Nexus 4 using Tapatalk
Originally posted by gearyt View Postok... I dropped it on the desk and the earthquake alarm set..
how do i reset ?
Is HS going to make the many many options avail ?
6. MOTION ALARM CANCELLATION DELAY
Motion alarm will be cancelled in the main controller and the
associated devices after the period of time set in this parameter. Any
motion detected during the cancellation delay time countdown will
result in the countdown being restarted. In case of small values,
below 10 seconds, the value of parameter 2 must be modified (PIR
sensor’s “Blind Time”).
Available settings: 1 - 65535
Default setting: 30 (30 seconds)
Parameter size: 2 [bytes]
Originally posted by gearyt View Postonce it goes into alarm, icon never resets
The default value for parameter 22 is 30 seconds.
The default value for parameter 24 is 0 which means that the alarm is reported but the cancellation is not.
The manual gives details of the various values / operating modes achieved with parameter 24.
Still doesn't alter the fact that the battery level is not reported for these Fibaro sensors but not sure if this is a device or HS issue. I did report this directly to Rich some time ago and as far as he was aware there wasn't a software issue but I've not had chance to ask users of other software yet if they get battery level reports.
Paul..
or download it direct from ftp://ftp.homeseer.com/updates/Beta/HSPI_ZWave.exe
Greig.Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Still trying to get to the bottom of the battery level device not updating on the Fibaro motion sensor, so I set a polling interval of 8 hours on the battery device. In the log I now see this every 8 hours:
Jul-02 04:32:03 Z-Wave Warning Queued command (Unknown) failed for Node 37 Z-Wave Fibaro On/Off Sensor Node 37 Root and is being re-queued for the next wake-up interval.
Jul-02 04:32:03 Z-Wave Warning UZB1: Device (Node 37) woke up, but queued command failed to be sent. Command=Poll Device
Paul..
