Hello
I have a heatIt thermostat.
It has a set point drop box between 4C and 32C (this is the status range value).
Unlike Spuds Nest thermostat plugin; it does not have a + or - button.
Can easy trigger take the
Zwave setpoint node value and +1 within the range.
I can see there is a variable event - but it seems you need to select a value and a offset (+/-?). For example 10+1 (which is no good if your at 15 as you want 16 and not 11 each time)
So I just want an offset... Ie the current value + 1.
I hope this makes sense, Is this possible?
