Originally posted by spike5884
View Post
HomeSeer is now available under Home Control in the Google Home App!
Originally posted by shill View PostThis worked just fine for me yesterday, but when I tried it this afternoon, it just keeps telling me "sorry, I'm not sure how to help with that".
Guest
Originally posted by philipi View PostStrange...
Just tried linking again and it failed...
But 6 devices showed up... About 20+ devices are missing...
Thoughts are always welcome.
-Philip
I believe from OP that only on/off devices will appear. Also voice control has to be enabled for the device to show up.
Originally posted by rjh View PostWe put in a fix for this, if anyone was seeing this issue, please try to link again and post if you still see an error.
Note that you may have to restart the Google Home as it seems to cache information and may continue to error. This goes for your browser also.
Is there anyway we can have the functionality match the amazon skill - where it only pulls the "Device Name" as opposed to Location 1 / Location 2.
Right now I have the devices listed as "Bedroom Light Bedroom Light 3"
You can give them a nickname, but it's tedious.cheeryfool
Originally posted by rjh View PostYes, but you will need build 326 or the latest beta 342. You will need to SSH to your box to manually update, instructions are at the beginning of this thread.
I dont see any instructions for Linux. Can anyone provide me instruction on how I can install 326. I'm on 318. When I click to check for updates It tells met there are non.
Originally posted by Igorski88 View PostI dont see any instructions for Linux. Can anyone provide me instruction on how I can install 326. I'm on 318. When I click to check for updates It tells met there are non.
On the Zee-2 there is a GUI option to update which should work. That said the below long math way should also work.
I updated last night from 318 to 342 here and my Zee-2 GUI still shows an update to 318 anyhoot.
You would utilize SSH via Putty on Windows or a terminal session in Linux.
Note if you have never done this before then google putty and WinSCP if you want to do this from Windows. IE: install Putty and WinsSCP.
WinSCP provides you with a nice explorer like interface to your Zee-2 box.
Basically the command line in Linux is just ssh homeseer@ipofhomeseerbox which is similar to using Putty.
Once you get there then you have to change to the HomeSeer directory ... make sure that HomeSeer is off when doing this. Also make sure you have a backup of the entire directory before doing this.
1 - SSH to Homeseer box
2 - cd /usr/local/HomeSeer
3 - sudo ./updatehs.sh 318
Guest
Originally posted by bahamabum View PostDiddled with nicknames still cannot get google home to understand me
Must be doing something wrong.
Also, the reason I named the master bedroom "Ceiling Light" and not just light is because I believe the term "light" or "lights" is used to control all devices in a room...So by saying "Turn on the master bedroom light" it would turn on every device in the room.
How to use colors with homeseer device?Please excuse any spelling and grammatical errors I may make.
Tasker Plugin / Speech Droid
Tonlof | Sweden
