Hello Greig,
Is there a way to pass to the HS3 multiple values from single device as part of a single string that are sent from the Arduino API? I have a module that is able to present two values but I am not able to capture them both in HS3.
For example: SendToHS (1,data) provides this output 1,30.2,1.023
HS 3 is able to see the 30.2 but not the 1.023
I am able to see the data in the Arduino serial output window.
Once received in HS3 I would like to assign the second value to another device.
Do you have any suggestions on how make this work?
Best Regards
Mark
Best Regards
Mark
