Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > Z-Tool+
Z-Tool+ Discussions about Z-Tool+ Z-Wave installation software
  #121
Old October 2nd, 2015, 07:43 AM
DESIi1's Avatar
DESIi1 DESIi1 is offline
Seer Plus
Question A way to get the node number
Could a way to get the node number be added?
  #122
Old October 2nd, 2015, 08:57 AM
rjh's Avatar
rjh rjh is offline
HomeSeer Technologies
Do you mean when a device is added, or after its added?
  #123
Old October 2nd, 2015, 09:00 AM
DESIi1's Avatar
Seer Plus
Node Number
After it had been added, going back into a large system and discovering each switch's node number.
i know I can use a Z-Troller, but using the cell phone would be great.
  #124
Old October 2nd, 2015, 09:14 AM
rjh's Avatar
rjh rjh is offline
The problem with that is that the Z-Wave interface (in this case the Z-Net or USB interface) has to be very close to the device you are detecting because the node information frame does not route. So if I added the ability to get the node info it most likely would only work for devices close to the controller, not ideal.
If you have a Z-Troller, you can add it as a secondary controller to your HS system and then carry that around to get the node #'s. Just remember to power it off when you are not using it.
  #125
Old October 5th, 2015, 10:17 AM
KSO KSO is offline
Z-Tool+ Can not connect
I installed the Z-Tool+ app and it sees my HS3 server, but a message appears that "Error: ConnectFailure (No route to host)"
I have the Enable control using JSON, checked.
I am using .206 and Z-Wave 3.1.37
  #126
Old October 5th, 2015, 10:31 AM
rjh's Avatar
rjh rjh is offline
If you to find.homeseer.com with a web browser, does your system appear there? If so, can you click on the link to access it?
  #127
Old October 5th, 2015, 10:50 AM
KSO KSO is offline
Yes it appears, and the link takes me to my HS3.
  #128
Old October 5th, 2015, 11:03 AM
rjh's Avatar
rjh rjh is offline
Odd, it should be working then, all the app does is connect to the IP address given by find.homeseer.com. What kind of device are you using and is it on the same wireless network as the PC you tried? Do you have another mobile device to try? It sounds like your mobile device cannot get to HS3. Can you bring up find.homeseer.com on the device you are running Z-Tool+ on, then connect to HS3.
  #129
Old October 5th, 2015, 12:51 PM
KSO KSO is offline
Red face
OK, it works if I join the correct network channel. I was on the guest channel
  #130
Old November 11th, 2015, 02:31 PM
jpape's Avatar
jpape jpape is offline
Originally Posted by macromark View Post
Right.. you mentioned that 7 posts ago. We get it! Makes sense. We'll check into it.
Any progress on this?
  #131
Old December 24th, 2017, 12:50 AM
Robert Willis Robert Willis is offline
Z-Tools+ Version 1.9 Broke ??
I have two different iPAD's that cannot get the Z-Tools+ application to work. Safari can connect to find.homeseer.com however Z-Tools+ immediately opens and then crashes.
I just received my HomeSeer products and so far I am not having any luck getting them to talk to a HomeTroller Zee S2 (US).
  #132
Old December 27th, 2017, 12:41 PM
rjh's Avatar
rjh rjh is offline
I see the issue with Z-Tool+ on IOS, looking into it.
  #133
Old December 28th, 2017, 11:04 AM
rjh's Avatar
rjh rjh is offline
Appears to be an issue with IOS 11 only but has been fixed. Version 1.11 has been submitted and is awaiting Apple approval.
Introducing MyHS Remote Access Service! macromark MyHS Remote Access Service 75 September 5th, 2017 08:19 PM
Introducing HS3-Pi macromark HS3-Pi Discussion 50 August 11th, 2016 02:42 PM
Well so much for the new search tool Rupp HomeSeer General Discussion Area 6 April 15th, 2004 12:29 PM
