Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Software > Z-Tool+
Z-Tool+ Discussions about Z-Tool+ Z-Wave installation software
Old August 15th, 2015, 02:20 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
Error
I went to add some devices this morning with Z-Tool+ and I'm getting an error that Z-Wave plugin 3.0.1.23 or higher is required. I'm running 3.0.1.25. WTH??
So, I'm stuck adding some devices. Grrrr.....
Old August 15th, 2015, 02:46 PM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
Rob - be sure you don't require a login for local access and also make sure that JSON is enabled in your settings.
Old August 15th, 2015, 03:16 PM
rmasonjr's Avatar
I've always had both enabled. It worked fine before the Z-Wave 3.0.1.25 version:
Old August 15th, 2015, 04:00 PM
Daweeze's Avatar
Daweeze Daweeze is offline
Rob,
I had the same issue. It was that my WiFi VLAN was different from my HS Server VLAN so I had to add it to the know local LAN list in HS. Same issue for you?
From the D23 Convention in Anaheim,
-Travis
Old August 15th, 2015, 04:02 PM
rmasonjr's Avatar
Originally Posted by Daweeze View Post
Rob,
-Travis
Hey Travis. I don't think thats it. I can access the HS Web GUI just fine.
Hope the weather's good on the left coast
Old August 15th, 2015, 05:13 PM
Daweeze's Avatar
Yeah pretty hot here actually! For California.... I could access the HS web page too but realized I had started being asked for my password which let me know that the local login w/o password wasn't working properly. It wasn't really accessing the webpage from my phone on the wireless network before other than HSTouch. Then, I was bummed the app wasn't working until I added another local exception of "192.168.6" in my case. Funny no fourth octet of "0" necessary but ok.
-Travis
Old August 16th, 2015, 12:02 PM
rjh's Avatar
rjh rjh is offline
go to find.homeseer.com on a web browser on your HS system, does your system appear? If so, ztool should be working. I know some users are putting HS on a different WAN ip than the actual PC, in that case, z-tool will not work. I will be adding a setting to Z-Tool so you can enter the IP of your HS system.
Old October 9th, 2015, 04:16 PM
mbreeden's Avatar
mbreeden mbreeden is offline
I am having the same issue with my Iphone. I can go to Find.homeseer.com and it sees the the server (via the IPhone). When I start the App, I get the message:
" Error connecting to HomeSeer, version 3.0.0.194 or later required, or JSON is disabled:Error ConnectFailure (Connection Refused).
I have JSON enabled and I am running .208
Getting Error 8021 (Internal error retrieving device control block for the port) MasterMog WAF-AB8SS (3P) 6 September 16th, 2006 05:44 AM
8/15/2005 5:37:40 PM Error Error Sending email: 502 Error: command not implemented paul@thekaufs.com HS2 / HSPRO 0 August 15th, 2005 06:27 PM
HTTP Error 408: Server Timed Out Error With Sanyo 8100 PCS Phone? Rick Bonari WapSeer (3P) 10 July 9th, 2003 11:04 AM
Help with Error Message, Script error in file: CH and HW Control temp.txt 0: in line 0 nigelgiddings Script & Plug-In Development 1 August 2nd, 2002 04:20 PM
