Originally posted by TechFan
View Post
HomeSeer lighting is Here!
Originally posted by kesterf View PostAny plans to offer in color "Light Almond"?Originally posted by macromark View PostNot initially. Perhaps later in the year.
Barry
Originally posted by markmm7 View PostCan the dimmer switch control a ceiling fan?
Originally posted by lhfarm View PostI made the mistake of install ivory colored outlets and switches when we remodeled. I also vote for ivory covers. Can't order until then.
Barry
Originally posted by jbbtex View PostInstalled my On/Off switch this afternoon. Looks good, and paired easily.
Using it in place of an Insteon KeypadLinc. Works nicely using both double-click and triple-click, which do not operate the load.
Quite happy with the product.
Originally posted by TeleFraggerThis may.. and I will stretch... May save me. to setup an association and a double tap turn on say under cabinet lights may do something but may not for the wife.
it switches on the main lights, sink lights, under cabs and also accent lighting.
did the same thing in the bedroom.HS3 Pro on Windows 8 64bit
53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
Check out my electronics blog here:
https://www.facebook.com/RaptorsIrrationalInventions
Originally posted by TechFan View PostIs there any specific reason not to use dimmers if the ramp rate can be set to act like on/off switch?HS3 Pro on Windows 8 64bit
Originally posted by Raptor View Posti use dimmers mainly so that i can adjust the light level. i have a few dimmers set on instant on as i have had guests get confused by the ramp on effect.
Originally posted by macromark View Postno. the HS-WS100+ switch can be used for on-off control of a fan. If you need a controller with speed adjustments, you'll need to GE fan controller that we carry.
Do the associations work for dimming like it does in insteon (the linked devices all dim together in unison when adjust the dim level)?
Sent from my XT1585 using Tapatalk
Reposting on this thread. I ordered 5 dimmers, 5 companions (2-way) & 2 relay switches on Tuesday to evaluate and they showed up today. I just installed the first relay with companion, straight forward, included via Z-Tool+ app and manually controlled from the web interface and HStouch with no issues.
I'm just starting to overhaul my old system (Stargate/HS2/X-10) with a brand new ZeeS2 and this was the first Z-Wave device I connected. Switches look like quality built hardware.
Pretty happy to see the price point on these better than anything else with instant status, and I hope to make use of the double tap to replicate something my old system does to ignore motion and timers to leave lights off/on.
John
