I am (finally) upgrading to HS3 and was very excited about this plug-in, but I'm having problems. I followed the instructions in the help file and in the forums and just compiling the sketch errors out with a bunch of text. Any chance I'm the only one using a USB connection with these versions? Does it matter what folder the HomeseerBoard1.ino file is in when I compile?
HS3 3.0.0.368
Arduino 1.6.8
Arduino Plugin 1.0.0.131 (unregisterd at this point)
I've copied the 5 library folders to D:\Program Files (x86)\Arduino\libraries
(yes, Arduino is installed on my D drive)
I'm selecting the following in the Arduino Plugin config before downloading the sketch:
Board #1: Connection = COM3
Type = Arduino
(no advanced settings)
When compiling the sketch, it errors out with 1500 lines of error messages (see attached file.)
HS3 3.0.0.368
Arduino 1.6.8
Type = Arduino
