Original Hub (Not Pro version)
    #31
    Jeff,
    On the home page you should see the lutroncaseta device if you did import, here the picture
      #32
      Jeff are you sure the IP of your smartbridge is 192.198.1.6?
        #33
        Not connected
        The line on the Home page shows:
        Telnet and SSH Not Connect
        And yes, checkiing with the router, the address is 192.168.1.6
        So I'm still stuck.
        Jeff
          #34
          Jeff,
          can you install the apps on your phone "Fing", then scan your network, you should see the Lutron with the IP, then click on it and scan services.
          After post me the available services.
            #35
            Here's what I have:
            (in attachments)
              #36
              Jeff, you set the IP in HS3 at 192.198.1.6 but it should be 192.168.1.6
                #37
                Wow, I figured it was a newbie mistake, but I looked at that address several times and misread it. Thanks!
                What should be my next steps to import the Lutron devices?
                  #38
                  Just go in the config, same place as you put the IP address and click the Import.
                  everything should appear in the home page.
                    #39
                    GREAT support. Thanks!!
                      #40
                      Just following, did you get the import and be able to control the device with the HS3?
                        #41
                        Yes Don, it's working well now. Of course I still have much to learn but now I can move forward doing so. Thanks again.
                          #42
                          Yes, its now working fine. Thanks!!
                            #43
                            I find the way to connect with the SSL now just need to integrate it to the plugin
                              #44
                              Excellent!
                              Secure comm. is always better.
                                #45
                                Great! let us know when you get it finished
                                Steve Q
